8 Core CPU running at 100% with Iclone only
Posted By FreddyKrueger 13 Years Ago
FreddyKrueger
FreddyKrueger
Posted 13 Years Ago
Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)
Posts: 97, Visits: 468
Anyone else have any issues running the CPU to 100%. I have the amd 8350 8 core CPU and if I try to resize iclone window in any way it shoots the CPU to 100%. I was having some slow downs last few days and I was wondering what could do this? Also, has anyone else been having these issues?
I heard some issues with Nvidia drivers but going back to last, most stable, driver did not solve the issue. I also tried running Zbrush with millions of polys and the cpu did not go over 25%. I ran Daz, Sketchup... you name it, and even together, nowhere near 100%. I tried resizing their windows too and nothing not a budge. Only happening with Iclone.
Here are two pics.
The first one is right after opening Iclone.
Second one is after moving the right side of the window in just a bit (resizing).
It literally shoots up to to 99 or 100 and then comes down. If I load a scene it shoots up to 99% and may stay there for few seconds. If I am working on any kind of hand animation it eventually hits 99%.
Alienware 15, i7 4710hq, GTX 970m, 16gb ram, 4k display, 1.5TB SSD raid.
Iclone CPU.PNG (300 views, 346.00 KB)
Threaded View
Threaded View
Forum Post 8 Core CPU running at 100% with Iclone only By FreddyKrueger ( 13 Years Ago )
Forum Post " If I am working on any kind of hand animation it eventually hits... By planetstardragon ( 13 Years Ago )
Forum Post I usually work in maximized Iclone. I just noticed that when I move... By FreddyKrueger ( 13 Years Ago )
Forum Post if you google around, there have been people having all sorts of... By planetstardragon ( 13 Years Ago )
Forum Post Freddy, I have some of the effects you are mentioning, such as slow... By animagic ( 13 Years Ago )
Forum Post [quote][b]animagic (7/19/2013)[/b][hr]Freddy, I have some of the... By FreddyKrueger ( 13 Years Ago )
Forum Post Yeah, I switched from 7950 to GTX680 (4gb ram). I found it to be... By FreddyKrueger ( 13 Years Ago )
Forum Post I still believe something happened with the latest version of iClone... By animagic ( 13 Years Ago )
Forum Post [quote][b]animagic (7/19/2013)[/b][hr]I still believe something... By FreddyKrueger ( 13 Years Ago )
Forum Post sw00000p, I wouldn't know off hand why...:unsure: By animagic ( 13 Years Ago )
Forum Post Freddy, that doesn't look like an excessively large project to me. By animagic ( 13 Years Ago )
Forum Post [quote][b]animagic (7/20/2013)[/b][hr]Freddy, that doesn't look like... By FreddyKrueger ( 13 Years Ago )
Forum Post My experience is only slowdown. So I use smaller players to view my... By DELETED2 ( 13 Years Ago )
Forum Post It was NVIDIA after all. Installed 7970, loaded the drivers, open... By FreddyKrueger ( 13 Years Ago )
Forum Post This is painful. I've used nVidia for years because ATI (now AMD)... By animagic ( 13 Years Ago )
Forum Post nvidia beta driver build 326.16 - running stable for me so far. By planetstardragon ( 13 Years Ago )
Forum Post [quote][b]animagic (7/20/2013)[/b][hr]This is painful. I've used... By FreddyKrueger ( 13 Years Ago )
Forum Post I was doing more research today on video cards, one drawback I... By planetstardragon ( 13 Years Ago )
Forum Post I am not partial, any longer, to either AMD or Nvidia. I just want... By FreddyKrueger ( 13 Years Ago )
Forum Post [quote][b]FreddyKrueger (7/20/2013)[/b][hr]Now that I think of it, I... By animagic ( 13 Years Ago )
Forum Post I have a firepro 5900 sitting around. I tried it today. Worked great... By FreddyKrueger ( 13 Years Ago )
Forum Post as far as I know the gpu plays a major role in rendering the ram... By planetstardragon ( 13 Years Ago )
Forum Post [quote][b]planetstardragon (7/21/2013)[/b][hr]as far as I know the... By FreddyKrueger ( 13 Years Ago )
Forum Post you may want to double check me on that though....for all I know the... By planetstardragon ( 13 Years Ago )
Forum Post I've run into some of the issues noted here since IC4.x ... for... By hgagne ( 13 Years Ago )
Forum Post A couple of years ago if you recall I had a more basic nVidea and I... By DELETED2 ( 13 Years Ago )
Forum Post I did some more research on the firepro cards. I use my firepro 5900... By FreddyKrueger ( 13 Years Ago )
Forum Post w7000 works great in IC. It runs on par with gtx680 as far as my test... By FreddyKrueger ( 13 Years Ago )
Forum Post i'm contemplating a gtx 760 gamer twin frozer - but really want a gtx... By planetstardragon ( 13 Years Ago )
Forum Post If you hang in there for a month or two you will see prices drop on... By FreddyKrueger ( 13 Years Ago )
Forum Post you can never be too prepared for what may come in the next iclone... By planetstardragon ( 13 Years Ago )
