marcelj29
marcelj29
Posted 13 Years Ago
Last Active: 6 Months Ago
Visits: 412
Good afternoon everyone, I have a question about the Physics Toolbox. I have watched all of the Tutorials on the Physics Toolbox and I must be missing something, because I have been unsuccessful at getting it to work correctly. Using motor A, and the Covered wagon from City elements-Old Western Town. I was able to get the wheel to rotate in the correction direction. I attached the wheels and motor A, back onto the Covered Wagon. When I hit the play button the Covered Wagon Moves, but motor A and the Wagon wheel doesn’t move with the wagon. I am not sure what I doing wrong, does anyone have any suggestion on how I fix this problem?
colour
colour
Posted 13 Years Ago
Posts: 5.2K,
Visits: 8.1K
IMO, since the covered wagon has 4 wheels you would need the relevant Physics tool for those & not Motor A, which is for a single Prop rotation eg; a fan or Propeller. I'm just going to fire-up iClone & check my Physics Toolbox, to see which tool you need. ADDED - Go to; Physics Toolbox / Structure / 07 Wheels. See Screenshot;
----------------------------------------------------------------------------------------- REALLUSION FORUM ANNUAL PINHEAD COMMUNITY PROJECTS. New Pinhead Website & Project to be announced in September 2015 -----------------------------------------------------------------------------------------
marcelj29
marcelj29
Posted 13 Years Ago
Visits: 412
Thank you very much. I will try that one.
Dushka
Dushka
Posted 11 Years Ago
Last Active: 6 Years Ago
Visits: 304
I have the same problem trying to move a bicycle with spinning wheels. The bicycle's body moves forward, but the wheels stay spinning on the spot. The Physics Toolbox doesn't have a two-wheel motor for wheels aligned longitudinally.
colour
colour
Posted 11 Years Ago
Posts: 5.2K,
Visits: 8.1K
 Welcome to the Forum. 1) Try Reallusion iPtop Bike. See Screenshot. 2) Physics Toolbox Motor A will Drive both wheels. You need to Select both. Screenshot
Posted 11 Years Ago
Last Active: 3 Weeks Ago
Posts: 15.8K,
Visits: 31.4K
I didn't even know we had such a cool bike... :blush: Learning something every day... :ermm:
Dushka
Dushka
Posted 11 Years Ago
Visits: 304
Thanks, Tutor. Unfortunately, I am still completely stumped, and totally frustrated with Physics Toolbox. I can get the wheels of the bike iProp to rotate successfully but still cannot get the bike to move forward. If I move the bicycle along a path, the bicycle frame breaks away from the wheels and moves along the path leaving the wheels locked to the spot spinning merrily. (I can get the bicycle moving forward with rotating wheels using the Control Menu script, but that's not what I'm trying to master right now.) But what is bothering me even more right now is that I cannot figure out how to play back any animation produced using the Physics Toolbox. The locked spinning wheels don't spin when I play back. For example, when I play back the bicycle moving along a path, the bike frame without its wheels moves forward but the wheels stop spinning. I see a clip in the animation track on the timeline, but if one hits the Play button, nothing happens. I can get primitive blocks to rock back and forth using the 04 Motor D prop, but once again, no success playing the animation back. I have the Rigid Body Simulation turned on. When I tinker with the Project files that come with the Physics Toolbox, I can get playback to work O.K. when I fiddle with the controls there. I reckon I have forgotten to do something very basic.
Dushka
Dushka
Posted 11 Years Ago
Visits: 304
Ah. I have just discovered the reason for failure to play back. For anybody else struggling with the same problem, the answer is here at https://www.reallusion.com/iclone/help/iclone5/PRO/20_Physics/The_Basics_of_Rigid_Body_Simulation.htm. But it's not well-written and you will need to read every sentence carefully. Unless I am mistaken, you have to hold down the Rigid Body Simulation icon while the simulation is taking place. Also, once the simulation is complete, do not click on that icon again or you will lose what you recorded! Very strange indeed. I am still at a complete loss as to "the bicycle problem".
mark
Posts: 4.9K,
Visits: 16.7K
I believe what you would do is click to activate the simulation then once you're happy with the result click again to turn off the simulation. I don't think you need to "hold-down" the simulation button.
Dushka
Dushka
Posted 11 Years Ago
Visits: 304
Thank you, Mark. I tried that, and you are quite right.
