Hi Drew,
For the first issue, please check you are using the latest version which is 7.2. There was a bug in the original 7.0 release but this should be fixed in the latest version.
For the second issue, unfortunately the Neospeech Voices are 3rd party products and they do have their own verification system which must be carefully followed first to register them.
Please follow the steps below for each voice using the serial provided.
You can refer to the full instructions to install NeoSpeech TTS as explained below:
http://file.reallusion.com/3rdParty/NeoSpeech/NeoSpeech_Installation_Guide_Windows.pdf
Please then download the Mac finder tool below and run this so you have your Mac address ready to enter when requested. (Note: This has nothing to do with Mac computers. It is a code used by all computers).
http://file.reallusion.com/3rdParty/NeoSpeech/WinHostID_MacAddress.zip
When ready, please go to the link below and enter in your License key which was supplied in your purchase email.
http://verification.neospeech.com/reallusion
Continue to follow the steps, filling in the information as requested. Once complete you will be given a verification file. At this point select "Save To File" and save as verification.txt.
This should then be placed in the folder below (example Bridget).
C:\Program Files\VW\VT\Bridget\M16-SAPI5\data-common\verify
or for 64Bit systems.
C:\Program Files (x86)\VW\VT\Bridget\M16-SAPI5\data-common\verify
Now the Demo warning should be removed. :)
