Nop3D
Nop3D
Posted 13 Years Ago
Last Active: 13 Years Ago
Visits: 154
I noted, thank you again Vidi and Peter
Posted 13 Years Ago
Posts: 23.1K,
Visits: 36.6K
Nop3D (4/29/2012) Hi Vidi,
I update graphic card driver already (Intel G33/G31 card) but the problem still exist.
How can I send image file to you for analyzing further ?
Please help.
Thank you
Hi Nop3D Unfortunately the graphics card is the problem here. The Intel G33/G31 graphics chips are quite old now and underpowered for CTA. If you have updated your graphics drivers and set the Max Real-time Map Settings to the highest available, then there isn't much you can do to improve the situation apart from getting a newer and more powerful graphics card. Sorry I can't offer better news.
vidi
Posts: 10.8K,
Visits: 40.2K
I think this is a limit of your graphic card . I can even choose 8192x8192.  quote from CTA Guide Maximum real-time map size
This setting decides the resolution rendered in the working area. If you encounter a blurry result, especially with image-based items, then try to increase the value of this setting to render the working area in higher resolution.
Nop3D
Nop3D
Posted 13 Years Ago
Visits: 154
I use trial version of CTA now, can set [Max real time map size] value only 2048x2048 (not have
4096x4096 to select), or is this limitation of trial version ? But for [Max image import size] I can
choose 8 million pixel.
vidi
Posts: 10.8K,
Visits: 40.2K
What is your max real time size ?
Nop3D
Nop3D
Posted 13 Years Ago
Visits: 154
Hi Vidi, Please find attachment (comparison.jpg), left image is imported file into CTA, the right is original. *********** Hi Kawatzakka, Thank you
Nop3D
Nop3D
Posted 13 Years Ago
Visits: 154
Kawatzakka
Kawatzakka
Posted 13 Years Ago
Last Active: 11 Years Ago
Visits: 492
You can include it as an attachment in your reply.
------------------ Win 7 64 bit - DirectX11 - NVIDIA GeForce GTX 560 Ti - 16 GB RAM - Intel Core i7-2600 @3.40GHz 3.40GHz
Nop3D
Nop3D
Posted 13 Years Ago
Visits: 154
Hi Vidi,
Please help.
Thank you
vidi
Posts: 10.8K,
Visits: 40.2K
I use other software but not have the problem like CTA regarding clear image. Not all Software use the same render technik. Have you been updated? Here you can check http://www.scirra.com/graphics-driver-updater.zipif yes, which card use you ? I can try your image on my CTA and compare .So we can analyze what is the issue.
