imported image quality
Posted By Nop3D 13 Years Ago
Nop3D
Nop3D
Posted 13 Years Ago
Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)
Last Active: 13 Years Ago
Posts: 30, Visits: 154
I noted, thank you again Vidi and Peter
Posted 13 Years Ago
Posts: 23.1K, Visits: 36.6K
Nop3D (4/29/2012)
Hi Vidi,
I update graphic card driver already (Intel G33/G31 card) but the problem still exist.
How can I send image file to you for analyzing further ?
Please help.
Thank you
Hi Nop3D
Unfortunately the graphics card is the problem here. The Intel G33/G31 graphics chips are quite old now and underpowered for CTA. If you have updated your graphics drivers and set the Max Real-time Map Settings to the highest available, then there isn't much you can do to improve the situation apart from getting a newer and more powerful graphics card.
Sorry I can't offer better news.
vidi
vidi
Posted 13 Years Ago
Posts: 10.8K, Visits: 40.2K
I think this is a limit of your graphic card .
I can even choose 8192x8192.
quote from CTA Guide
Maximum real-time map size
This setting decides the resolution rendered in the working area. If you encounter a blurry result, especially with image-based items, then try to increase the value of this setting to render the working area in higher resolution.
liebe Grüße vidi
Nop3D
Nop3D
Posted 13 Years Ago
I use trial version of CTA now, can set [Max real time map size] value only 2048x2048 (not have
4096x4096 to select), or is this limitation of trial version ? But for [Max image import size] I can
choose 8 million pixel.
vidi
vidi
Posted 13 Years Ago
What is your max real time size ?
liebe Grüße vidi
Nop3D
Nop3D
Posted 13 Years Ago
Hi Vidi,
Please find attachment (comparison.jpg), left image is imported file into CTA, the right is
original.
Hi Kawatzakka,
Thank you
Nop3D
Whistling
Nop3D
Posted 13 Years Ago
Kawatzakka
Kawatzakka
Posted 13 Years Ago
Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)
Last Active: 11 Years Ago
Posts: 229, Visits: 492
You can include it as an attachment in your reply.
Win 7 64 bit - DirectX11 - NVIDIA GeForce GTX 560 Ti - 16 GB RAM - Intel Core i7-2600 @3.40GHz 3.40GHz
Nop3D
Nop3D
Posted 13 Years Ago
Hi Vidi,
Please help.
Thank you
vidi
vidi
Posted 13 Years Ago
I use other software but not have the problem like CTA regarding clear image.
Not all Software use the same render technik.
Have you been updated?
Here you can check
http://www.scirra.com/graphics-driver-updater.zip
if yes, which card use you ?
I can try your image on my CTA and compare .So we can analyze what is the issue.
liebe Grüße vidi
