imported image quality
Posted By Nop3D 13 Years Ago
Nop3D
Nop3D
Posted 13 Years Ago
Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)Veteran Member (532 reputation)
Last Active: 13 Years Ago
Posts: 30, Visits: 154
Dear all,
I import image file to CrazyTalk Animator by "import media"
button,either select "prop", "image layer" or "background" The result of image quality is not
sharp as original. My image file is my PC screenshot.
Support team advise me to adjust "max real time map size" to high value. Moreover I increase
"Maximum image import size" too, but the result is still not good.
Support team suggest more that image should have resolution at lease 1024 x 1024 but
sometime image that I want to show in CTA is not high quality like that.
Can someone advise how to solve this problem ?
I hope the method is not to update graphic card driver.
Thank you very much
vidi
vidi
Posted 13 Years Ago
Posts: 10.8K, Visits: 40.2K
In the most case is this the solution .:D
When this and the another suggestions not solve this problem, I have no idea.
I have not this problem ,I get all my images clear . So I think really it is your graphic-card. :ermm:
liebe Grüße vidi
Nop3D
Nop3D
Posted 13 Years Ago
I use other software but not have the problem like CTA regarding clear image.
Thank you Vidi to sharing.
vidi
vidi
Posted 13 Years Ago
Not all Software use the same render technik.
Have you been updated?
Here you can check
http://www.scirra.com/graphics-driver-updater.zip
if yes, which card use you ?
I can try your image on my CTA and compare .So we can analyze what is the issue.
liebe Grüße vidi
Nop3D
Nop3D
Posted 13 Years Ago
Hi Vidi,
I update graphic card driver already (Intel G33/G31 card) but the problem still exist.
How can I send image file to you for analyzing further ?
Please help.
Thank you
Kawatzakka
Kawatzakka
Posted 13 Years Ago
Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)
Last Active: 11 Years Ago
Posts: 229, Visits: 492
You can include it as an attachment in your reply.
Win 7 64 bit - DirectX11 - NVIDIA GeForce GTX 560 Ti - 16 GB RAM - Intel Core i7-2600 @3.40GHz 3.40GHz
Nop3D
Whistling
Nop3D
Posted 13 Years Ago
Nop3D
Nop3D
Posted 13 Years Ago
Hi Vidi,
Please find attachment (comparison.jpg), left image is imported file into CTA, the right is
original.
Hi Kawatzakka,
Thank you
vidi
vidi
Posted 13 Years Ago
What is your max real time size ?
liebe Grüße vidi
Nop3D
Nop3D
Posted 13 Years Ago
I use trial version of CTA now, can set [Max real time map size] value only 2048x2048 (not have
4096x4096 to select), or is this limitation of trial version ? But for [Max image import size] I can
choose 8 million pixel.
