Post your Physics Toolbox feedback HERE!
Posted By Bruce (RL) 14 Years Ago
greglh
greglh
Posted 12 Years Ago
Veteran Member (625 reputation)Veteran Member (625 reputation)Veteran Member (625 reputation)Veteran Member (625 reputation)Veteran Member (625 reputation)Veteran Member (625 reputation)Veteran Member (625 reputation)Veteran Member (625 reputation)Veteran Member (625 reputation)
Posts: 13, Visits: 60
I already started a thread with the suggestion before seeing this, but I will ask if those of you who have experience with the physics toolbox are able to make a vehicle with a trailer. Utility trailer. Boat trailer. 18 wheeler trailer. Keeping in mind that works as it should with regard to physics. Thanks!
txon
txon
Posted 14 Years Ago
Distinguished Member (8.4K reputation)Distinguished Member (8.4K reputation)Distinguished Member (8.4K reputation)Distinguished Member (8.4K reputation)Distinguished Member (8.4K reputation)Distinguished Member (8.4K reputation)Distinguished Member (8.4K reputation)Distinguished Member (8.4K reputation)Distinguished Member (8.4K reputation)
Posts: 827, Visits: 9.0K
Someone can tell me how they are recorded with the box of physical movements, I must be very donkey then fail to do so
Alguien me puede decir como se graban los movimientos con la caja de fisica, debo de ser muy burro pues no consigo hacerlo
thebiz.movies
thebiz.movies
Posted 14 Years Ago
Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)
Posts: 2.1K, Visits: 42.3K
Any physics toolbox experts out there?
Can a conveyor belt be attached to a moving object? The base can but the rollers have a world hinge constraint that allows them to roll but keeps them in place regardless of the attachment. I need a conveyor belt on a moving vehicle for my contest entry.
Any thoughts?
thebiz.movies
thebiz.movies
Posted 14 Years Ago
Another interesting force to include in the future would be an attraction force that could be toggled on and off.
thebiz.movies
thebiz.movies
Posted 14 Years Ago
thebiz.movies (5/15/2012)
Can a force (push or explosion) be attached to an object and affect that object each time it is used? For instance can a bomb be attached to a block to continuosly push the block each time it is enacted?
I finally found the tutorial on the push force and figured this one out (I think).
A groovy addition to these tools would be the ability to activate them if/when they come in contact with other physics enabled props. For instance, a pinball table could have the bomb force activated when the ball hits the bumper.
thebiz.movies
thebiz.movies
Posted 14 Years Ago
GimpMedia
GimpMedia
Posted 14 Years Ago
Last Active: 10 Years Ago
Posts: 86, Visits: 967
Is it possible to attach a soft body to one of the props and have it record? If I disable the physics, it kooses the soft body properties
Posted 14 Years Ago
Posts: 23.1K, Visits: 36.6K
ingie01 (3/28/2012)
I posted separately about the physics objects do not render in the main window. Is the deleting of dummys a work around or is this a bigger problem?
You should be able to toggle the dummy objects on or off by pressing CTRL-D. Most likely they have been turned off at some point. Just turn them back on and you should be good to go.
ingie01
ingie01
Posted 14 Years Ago
Posts: 49, Visits: 1.2K
brystudio
brystudio
Posted 14 Years Ago
Last Active: 11 Years Ago
Posts: 210, Visits: 244
OK my bad was watching video and realized looking in wrong place opps. All better now found them:hehe:
