Sasha. Cloths preview.
Posted By Vit3D 14 Years Ago
Vit3D
Vit3D
Posted 14 Years Ago
Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)
Last Active: 6 Months Ago
Posts: 917, Visits: 15.1K
Hi All.
March has come and, as promised, I'm ready to show preview of first (but not last) cloths collection for PR5 female Sasha. ;)
This collection based on 3 Lower basic shapes
and 5 Upper basic shapes
Each lower model has additional element (sub-layer) for belt creating. L3 is official (business) female trousers; it has higher waist cut and wider belt element.
Upper models U0-U1 and U3-U4 also have tucked (UxT) versions; U4 has additional loosed (UxL) version.
Shapes U0 and U1 (both tucked and loosed versions) represent first upper cloths layer (UpperA).
Upper shape U0 is different from others -- it has no cloths relaxation between breast (all other have natural relaxed look in this zone). U0 useful for top underwear creation (if it will be visible through second upper cloths layer UpperB).
Shapes U0T, U1T and U1L used in LowerPlus (LP) models construction. This way collection includes 9 unequal LowerPlus shapes.
Think I should remind that LowerPlus is expanded modification of Lower cloths part specially created for multi-layers Upper cloths constructing.
LowerPlus consists of 3 elements -- Lower body, Lower Cloths and Close-to-Skin Upper cloths (first layer of upper cloths).
When You put LowerPlus on your character and then put some Upper cloths, You do NOT REPLACE first layer of upper cloths (which is the part of LowerPlus), but ADD new (second) layer of upper cloths.
(This picture shows only few of valid combinations)
Shapes U2, U3 and U4 (both tucked and loosed versions) represent second upper cloths layer (UpperB).
All models on these shapes have additional elements (sub-layer) for collar and wristbands creating. Unlike the male cloths pack this sub-layer used the same material (UpperB) as main cloths object. I decided "preserve" separate material (UpperD) for assigning to big upper elements (like hood for example) in future packs.
Texture layout.
Although collection includes a lot of models they used only 3 basic texture layouts (UV):
- All Lower models (and lower parts of LowerPlus) have the same texture layout;
- Models U0-U2 (and modifications) have the same texture layout;
- Models U3 and U4 (and modifications) have the same texture layout;
This way if material have been created for one model it can fit all models in the same group.
Shoes fitting.
Unfortunately High Heels creating procedure recommended for G5 (Flat Shoes and High Heels shoes must have the same foot bone rotation) cause some problems with skinning bottom of pants -- it's not possible to make universal skinning for long and/or wide pants which will has natural bottom deformation for both Flat and High Heels shoes when character bend foot.
L1 model of pants rather tight and short and this issue practically does not affect on this model. Initially L1 model have been skinned for High Heels shoes but You will have no visual issues in wide range of foot bending for flat shoes too. Although if You wish completely avoid this issue You should make this pants a bit shorter (apply opacity mask up-to first bottom guide line in template) for using with flat shoes.
L3 trousers in most of cases used with High Heels shoes, so it was skinned for High Heels. Using L3 with flat shoes can cause issue (pants-to-shoes intersection) on foot bend (or they must be shorter).
L2 (classic jeans) commonly used with both flat and High Heels shoes, but this model does not allows universal rigging. So I have to include separate models for fitting to different types of shoes -- L2f and L2h. Both modifications have absolutely identical shape, but L2f rigging to fit Flat Shoes and L2h - High Heels.
Cloths Packs.
Working at this project I tried to give as many combinations as possible and as result this collection includes 22 unequal models (26 if take in count L2f-L2h modifications).
It's rather big number of models, so this collection will be published as 2 packs.
PR5FC_CL0 pack will include:
4 Lower models -- L1, L2(f/h), L3
3 Upper models -- U0L, U1L, U2L
Using this pack You will be able to create 9 unequal combinations of single layer cloths.
Also upper models from this pack can be combined with Lower SkinSuit model.
PR5FC_CL1 pack will include:
12 LowerPlus models - LP1U0T, LP1U1T, LP1U1L, LP2fU0T, LP2fU1T, LP2Uf1L, (the same for PL2h), LP3U0T, LP3U1T, LP3U1L
7 Upper models (for second layer) - U3L1, U3T1-2, U3T3, U4L1, U4L2, U4T1-2, U4T3
Using this pack You will be able to create 39 valid unequal combinations.
Also upper models from this pack can be combined with Lower and LowerPlus SkinSuit models.
Total number of valid unequal combinations for complete collection (CL0 + CL1) equal 61 ;)
Also both packs will include Gwynn shoes fitted for PR5 female as bonus.
Currently all models practically ready for sell, I just need prepare them for publishing (promos, descriptions etc.)
After this I'm going to make some fashions (materials) for these models, which will be published separately.
If some of fashion artist (materials developers) interested in creating materials for sell on the base of this collection, please contact me by PM.
Hope these products will be useful :)
Vit
Threaded View
Threaded View
Forum Post Sasha. Cloths preview. By Vit3D ( 14 Years Ago )
Forum Post These look amazing Vit,... As always, you have surpassed yourself... By Bigboss ( 14 Years Ago )
Forum Post A lot of thanks Bigboss! :) And You are right -- It was most complex... By Vit3D ( 14 Years Ago )
Forum Post Profesional Work with class, Welldone my friend By W.VEEKE ( 14 Years Ago )
Forum Post Very good work Vitaly . By Sen ( 14 Years Ago )
Forum Post Excellent work as always Vit. Beautiful! Shy :) By shygirl ( 14 Years Ago )
Forum Post Wil, Sen, Shy. Thank very much for nice comments! Glad that You like... By Vit3D ( 14 Years Ago )
Forum Post I'm in line to buy soon as it hits the market. By MrStockboto ( 14 Years Ago )
Forum Post Fantastic work as always By duchess110 ( 14 Years Ago )
Forum Post Hi BristolDuncan! Think You will have such possibility this weekend... By Vit3D ( 14 Years Ago )
Forum Post Wow :D By Capemedia ( 14 Years Ago )
Forum Post Excellent indeed! Very detailed, careful an extremely well crafted!... By Apparition ( 14 Years Ago )
Forum Post Capemedia and Mike, a lot of thanks for comments! :) Mike, I... By Vit3D ( 14 Years Ago )
Forum Post It looks like very good engineering. I still have the doubt: are... By Apparition ( 14 Years Ago )
Forum Post These look great!!! Is it too late to add a skirt to the pack? By sjonesdc ( 14 Years Ago )
Forum Post Mike, I understand your question. As I told this counter from "Project... By Vit3D ( 14 Years Ago )
Forum Post Thanks sjonesdc ! :) Skirts, dress, coats, overcoats and shoes... By Vit3D ( 14 Years Ago )
Forum Post [quote][b]Vit3D (3/2/2012)[/b][hr]Thanks sjonesdc ! :) Skirts,... By sjonesdc ( 14 Years Ago )
Forum Post To Power. [b]About thumbs...[/b] I know about this issues (legs... By Vit3D ( 14 Years Ago )
Forum Post Hi: Vit3D, if you can include garment for Sasha as News Presenter I... By power ( 14 Years Ago )
Forum Post This system looks great, but I find it ususable. It's so complex that... By peteradam6 ( 14 Years Ago )
Forum Post Not having done much texturing for Vit3D lately due to beta testing... By duchess110 ( 14 Years Ago )
Forum Post If you are having trouble with a particular purchased outfit, you... By Alley ( 14 Years Ago )
Forum Post peteradam6, sorry for some delay with the answer and I'd like to thank... By Vit3D ( 14 Years Ago )
