observer
observer
Posted 16 Years Ago
Last Active: 6 Years Ago
Visits: 9
When I try to download the codec to output to MP4, the system just hangs.
I need the MP4 codec ....
What do I do?
Chris
Posted 16 Years Ago
You shouldn't need to download any additional codecs. The codec is included and MP4 video can be outputted directly from Crazytalk 5. You should install Quicktime if you haven't already so that you can play back MP4 videos.
fredlunau
fredlunau
Posted 16 Years Ago
Last Active: 14 Years Ago
Visits: 7
When I try to output to MP4, I'm asked to activate the MP4 codec. When I do that in the browser that pops up, I continually get an error message when accessing the http://www.reallusion.com/ExporterActivation/activation.aspx page.
Could someone please look into this - I need MP4 pretty badly...
Thanks, Fred
Posted 16 Years Ago
fredlunau (10/22/2008) When I try to output to MP4, I'm asked to activate the MP4 codec. When I do that in the browser that pops up, I continually get an error message when accessing the http://www.reallusion.com/ExporterActivation/activation.aspx page.
Thanks, FredHi Fred, I just tested the activation system and it appears to be working ok now. A couple of things to remember. Please make sure you login with the same account that Crazytalk is registed to. This is very important. Then follow the steps precisely and it should work ok. If you continue to have problems you can contact support for further help. http://www.reallusion.com/CustomerSupport/User/QForm.aspx.
mark_20090922182633731
Posted 15 Years Ago
Last Active: 15 Years Ago
Visits: 1
I have the same problem. After clicking to activate, it opens IE and it just stays at "Webiste found. Waiting for reply..." and never comes up. It's been doing this for 24 hours now. Frustrating.
Posted 15 Years Ago
mark (3/22/2009) I have the same problem. After clicking to activate, it opens IE and it just stays at "Webiste found. Waiting for reply..." and never comes up. It's been doing this for 24 hours now. Frustrating.Hi Mark, There is a problem with the activation page at the moment. I'll look into it. It should be fixed soon. Apologies for the inconvenience.
ebsi
Last Active: 12 Years Ago
Visits: 4
Im having same problem
it says Reallusion MP4, 3GP Codec Activation Activation failed!! The following issue may cause the activation to failed :
Our Server is busy, please try it again. Your program serial number may be locked or being used by other users. Please contact our customer service.
Posted 12 Years Ago
ebsi (6/13/2012) Im having same problem
Our Server is busy, please try it again. Your program serial number may be locked or being used by other users. Please contact our customer service.If you are continuing to have this issue, please contact Tech Support using the link below. They will be able to help you further. http://www.reallusion.com/CustomerSupport/User/QForm.aspx
