iClone5 Heightmap Terrain Creation Process
Posted By Exchanger 15 Years Ago
Exchanger
Exchanger
Posted 15 Years Ago
Veteran Member (984 reputation)Veteran Member (984 reputation)Veteran Member (984 reputation)Veteran Member (984 reputation)Veteran Member (984 reputation)Veteran Member (984 reputation)Veteran Member (984 reputation)Veteran Member (984 reputation)Veteran Member (984 reputation)
Last Active: 7 Months Ago
Posts: 47, Visits: 1.7K
Here we finally put together the heightmap design process for whoever has the previous experience over Earth Sculptor.
http://www.reallusion.com/iclone/icnb_home.asp
Some Nice Features For The New Heightmap Terrain System
1. Large Terrain Size- around 9 times of iClone4 terrain size
2. Using multiple texture tiles instead one big texture image, save memory space
3. Much better rendering performance when LOD on (Ctrl-L)
4. Fast picking, easier to apply plantation (grass, tree), snap or walk on terrain, and terrain physics collision
5. Better self-cast shadow quality
6. Keep high texture detail in close view
7. keep high texture detail on vertical surface, such as cliffs
8. Future Terrain Expansion - connect height map terrains to form a bigger terrain; or endless terrain navigation
Here is the design procedure
1. Generate 3D Terrain from EarthSculpter, with map size 513x513
2. Export either OBJ or gray scale height map
You can use either obj or jpeg heightmap, we suggest you use obj for better detail
* Approach A: Load OBJ as the terrain mesh for iClone5 (smooth, higher detail)
* please don't turn on other settings, only "center on origin"
* Approach B: Load Height map (png, jpg, bmp) as the terrain for iclone5 - this can be easily edited by image editor
3. Use Earth Sculpter to create the color Mask file for 4 terrain textures
4. Save map, you will see all related texture maps are created in the same map folder
- the xxx_d.png file is the mask file using RGB+Alpha to keep the 4 color channel information
5. Edit the INI file, please see the sample terrain file
download the sample from here
http://dl.dropbox.com/u/2471042/Forum/terrain-test.zip
6. Under iClone5 Terrain tab, press Alt-Shift-J to load Terrain defined in the INI file
Terrain Script in the INI file
Supported Image Formats: JPEG, PNG, BMP
[HeightMap]
file = "test.obj" ; file name for gray scale height map image or obj model
cell_unit = 100 ; 100 cm
height_scale = 50.0 ; relative scale, 50 = 1:1 to OBJ file
offset_x = -12800.0 ; no use
offset_y = -12800.0 ; no use
offset_z =0 ; 0 to align default height of iclone 0,0,0 world axis
[MaskMap]
file = "test_d.png" the mask file generated from EarthSculptor
[Material]
count = 4 ; total material number
[Material0]
diffuse_r = 1.0
diffuse_g = 1.0
diffuse_b = 1.0
specular_r = 0.0
specular_g = 0.0
specular_b = 0.0
ambient_r = 1.5
ambient_g = 1.5
ambient_b = 1.5
shininess = 0.5
shineStrength = 1.0
decal_uv_tile_x = 24.0 ;; color map tiling x
decal_uv_tile_y = 24.0 ;; color map tiling y
decal_uv_tile_z = 24.0 ;; color map tiling z for vertical surface, eg. cliff
decal_uv_offset_x = 0.0
decal_uv_offset_y = 0.0
decal_uv_offset_z = 0.0
decal_uv_rotate = 0
detail_uv_tile_x = 60.0 ;; detail map (blend map)
detail_uv_tile_y = 60.0
detail_uv_offset_x = 0.0
detail_uv_offset_y = 0.0
detail_uv_offset_z = 0.0
detail_uv_rotate = 0
bump_uv_tile_x = 10.0 ;; bump map
bump_uv_tile_y = 10.0
bump_uv_tile_z = 10.0
bump_uv_offset_x = 0.0
bump_uv_offset_y = 0.0
is_normal_bump = false ;; if using normal map, value = true
bump_map_weight = 0.5 ; same as iclone strength setting
decal_map = "shortGrass.png" ;;decal map = diffuse map or color map
bump_map="beehive001.jpg"
detail_map="stoneWall1_tileable_1024.jpg"
[Material1]
diffuse_r = 1.0
diffuse_g = 1.0
diffuse_b = 1.0
specular_r = 0.0
specular_g = 0.0
specular_b = 1.0 ;; you can see blue specular on brown sand
ambient_r = 1.5
ambient_g = 1.5
ambient_b = 1.5
shininess = 0.5
shineStrength = 1.0
decal_uv_tile_x = 12.0
decal_uv_tile_y = 12.0
decal_uv_tile_z = 12.0
decal_uv_rotate = 0
detail_uv_tile_x = 15.6842
detail_uv_tile_y = 15.6842
bump_uv_tile_x = 1.0
bump_uv_tile_y = 1.0
bump_uv_tile_z = 1.0
decal_map = "brownsand.png"
[Material2]
diffuse_r = 1.0
diffuse_g = 1.0
diffuse_b = 1.0
specular_r = 0.0
specular_g = 0.0
specular_b = 0.0
ambient_r = 1.5
ambient_g = 1.5
ambient_b = 1.5
shininess = 0.5
shineStrength = 1.0
decal_uv_rotate = 0
bump_uv_tile_x = 3.0
bump_uv_tile_y = 3.0
bump_uv_tile_z = 3.0
decal_map = "bigRockFace.png"
[Material3]
diffuse_r = 1.0
diffuse_g = 1.0
diffuse_b = 1.0
specular_r = 0.0
specular_g = 0.0
specular_b = 0.0
ambient_r = 1.5
ambient_g = 1.5
ambient_b = 1.5
shininess = 0.5
shineStrength = 1.0
decal_uv_rotate = 0
decal_map = "orangesand.png"
*sample project in iclone5
*sample project in Earth Sculptor
Threaded View
Threaded View
Forum Post iClone5 Heightmap Terrain Creation Process By Exchanger ( 15 Years Ago )
Forum Post Thanks for that. I have Earth Sculptor and wondered if it would still... By animagic ( 15 Years Ago )
Forum Post thanks for detailled . By Sen ( 15 Years Ago )
Forum Post Hi! All, I have made some revision over the heightmap terrain guide.... By Exchanger ( 15 Years Ago )
Forum Post Hi, We followed all the steps given in the posting. However, when... By BodhaGuru ( 14 Years Ago )
Forum Post Are you using the "Detail" tool as described in step 3 to create the... By Exchanger ( 14 Years Ago )
Forum Post Thank you very much for this "ini"formation ! :cool: Best tripfreak... By tripfreak ( 14 Years Ago )
Forum Post [img]http://dl.dropbox.com/u/48415327/ini.jpg[/img] Any Idea what... By vidi ( 14 Years Ago )
Forum Post @Exchanger Thanks for your reply. We were missing the INI file as... By BodhaGuru ( 14 Years Ago )
Forum Post It works now , but strange I have only all copied in the terrain... By vidi ( 14 Years Ago )
Forum Post Just so I'm clear... In order to use this new capability of IC5 (high... By AverageJoe ( 14 Years Ago )
Forum Post I have some questions about the possibility to create some terrains or... By RobertoColombo ( 14 Years Ago )
Forum Post Not everyone can afford PhotoShop....however, an alternative that I am... By martok2112 ( 14 Years Ago )
Forum Post Apparently our replies were in just scant seconds of each other in... By martok2112 ( 14 Years Ago )
Forum Post paint shop pro has been pretty good for me - it's compatible with some... By planetstardragon ( 14 Years Ago )
Forum Post its awesome it works grt for me just i can add upto 4 textures... By queryamit ( 14 Years Ago )
Forum Post I love layering in PhotoShop....and hell, I just now learned how to... By martok2112 ( 14 Years Ago )
Forum Post I agree, layers are your friend... I try to cover my limited modeling... By animagic ( 14 Years Ago )
Forum Post I feel "Foolish";) [quote][b]animagic (6/22/2012)[/b][hr]I agree,... By colour ( 14 Years Ago )
Forum Post I'd really like to get back to the actual topic. How do we make use... By AverageJoe ( 14 Years Ago )
Forum Post I concur with wizaerd. The questions were simple and clear, the... By RobertoColombo ( 14 Years Ago )
Forum Post I couldn't agree more, Roberto. Solid answers are what's being asked... By martok2112 ( 14 Years Ago )
Forum Post Just a small contribution hope it helps I tried various programs for... By nl2012 ( 14 Years Ago )
Forum Post Hi there, I resurface this old thread for 2 reasons: 1. I had... By RobertoColombo ( 10 Years Ago )
Forum Post Sure would be ALOT of help, if someone who really understands and can... By rampart ( 14 Years Ago )
Forum Post Hi Rampart, Have you looked through the tutorial videos for Earth... By Peter (RL) ( 14 Years Ago )
Forum Post [quote][b]Peter (RL) (10/1/2012)[/b][hr]Hi Rampart, Have you looked... By Shaky ( 14 Years Ago )
Forum Post [quote][b]Shaky (10/1/2012)[/b][hr] How do you get Earth Sculptor? I... By Peter (RL) ( 14 Years Ago )
Forum Post [quote][b]Peter (RL) (10/2/2012)[/b][hr][quote][b]Shaky... By Shaky ( 14 Years Ago )
