iClone5 Issues Thread
Posted By Peter (RL) 15 Years Ago
Cricky
Cricky
Posted 15 Years Ago
Skype ID= learn.iclone
Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)
Posts: 2.8K, Visits: 13.8K
Just something that recently popped up.. THE BLUE RL Update Button in the task bar.
Note : whoever coded it, needs to check it again...it goes here:
http://www.http.com//www.reallusion.com/iclone/
SKYPE ID: rc.650
AverageJoe
AverageJoe
Posted 15 Years Ago
Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)
Posts: 2.4K, Visits: 10.1K
moviemachine (9/28/2011)
wizaerd (9/28/2011)
Chuck really doesn't like the Indoor Project. In fact, he really kinda flips out over it. See screenshot.
If you uncheck foot contact box on side panel Chuck straightens out;)
What do I lose by unchecking that?  By unchecking it, does it mean he won't be making contact on the floor of the Indoor Project, which in turn may (or may not) cause other issues down the line?
AverageJoe
AverageJoe
Posted 15 Years Ago
Doesn't the real time puppeteering supercede the CrayTalk pipeline?  meaning what you can do in CrazyTalk for iCLone avatars, you can now do directly in iClone?
Posted 15 Years Ago
Posts: 23.1K, Visits: 36.6K
shygirl (9/28/2011)
I am disappointed to hear that it will be a tutorial workaround to fix this distortion.  I was hoping that Reallusion would release a patch to fix the G2 problem.  Not only have people purchased the G2 Clone Cloth packs which were extensive but also additional content from Reallusion content store and marketplace.  There is a lot of G2 content out there and it is a really good clone cloth.
I reported this flaw very quickly after release and I hope Reallusion will look at this again and consider a patch.
Shy
Hi Shy
The problem you are having with the G2 avatars is one that can't currently be patched unfortunately. It really is a situation where to be able to use the HumanIK, the avatars need to have a certain bone structure.
Now the retargeting for G3 avatars is good but sadly G2 avatars do have some problems. There really was no simple way around this if HumanIK and the other advancements in animation were to be included in iClone5. The team will continue to look at this issue though.
Posted 15 Years Ago
mrmidi72 (9/28/2011)
Hi Everybody!
I've noticed (at least on my PC) that when you make a character talk (in the TYPE mode as in the IMPORT mode), it is terribly in late by the audio with the lip sync (under pixel shading).
Any Idea?
Thanks for any reply
It's very difficult to say without knowing your system specifications. If you contact Tech Support using the link below and supply your system information they should be able to help you with this issue.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx
Thanks.
Posted 15 Years Ago
silpa.mulpuri (9/28/2011)
Iam very disappointed that we cannot launch crazytalk to iclone 5 directly like we had the option in iclone 4. we have to take the crazytalk separately and do the facial animation and then we have to import that one to iclone 5.Is it correct?
or Is there a crazytalk option in iclone 5 which i cant see?
Hi Shilpa
The facial animation system used in iClone5 is now almost identical to that of CrazyTalk 6. This means that CT6 is no longer required in the same way as it used to be for getting the best facial animation in iClone. However the ability to import .cts script files from CrazyTalk is still there should you wish to import any files you may have created.
Thank you for the feedback.
Cricky
Cricky
Posted 15 Years Ago
When adding props, such as rocks to the scene, and subsequently "adding" to terrain, the paths recognize them as terrain, but it appears objects do not...
Cycled right through the rock using Gorf in the seat, even though the cycle was on path and was linked to the path it ignored the setup of the rocks as terrain parts.
The answer is Yes, the box was checked to use bounding mesh, before that question is asked.
I'll try another project to see what happens, but for now it is a glitch.
SKYPE ID: rc.650
Cricky
Cricky
Posted 15 Years Ago
Peter (RL) (9/28/2011)
shygirl (9/28/2011)
Shy
Hi Shy
The problemyou are having with theG2 avatarsis one that can't currently be patched unfortunately. It really is a situationwhere to be able to use the HumanIK, the avatars need to have a certain bone structure.
Now the retargeting for G3 avatars is good but sadly G2 avatars do have some problems. There reallywas nosimpleway around thisif HumanIK and the other advancements in animationwere to be included in iClone5. The team will continue to look at this issue though.
So why not apply the old mesh to the new boneset and update the packs?
SKYPE ID: rc.650
moviemachine
moviemachine
Posted 15 Years Ago
Last Active: 10 Years Ago
Posts: 260, Visits: 2.7K
shygirl (9/28/2011)
Shy
Hi Shy
Surprise... Surprise... the typical Reallusion dance.
I remember many questions asked regarding older avatar compatability with IC5 and the answer being they should be.
How can this company in clear conscience pull the rug out from the customers who have spent a fortune on G2 cloth and other products.
How long before Reallusion pulls the rug out on the next batch of suckers who buy into G3 and G5.
Should is such a convenient word for what I think is a tactical move to force (herd) users to
buy the next overpriced G5 material coming down the pipe.
On the one hand yes IC5 appears to have some really cool bells & whistles, but it is becoming more evident that this version was rushed for release.
I urge all Iclone users to boycott further product purchases until the G2 problem is fixed.
Being a guinea pig to iron out the bugs is one thing, but having peoples G2 libraries rendered useless goes beyond being sad.
Cricky
Cricky
Posted 15 Years Ago
Here is another issue not discovered until now...pertaining to the terrain also.
Moon Walking and Watermelon Crawling... See the Crawl at 21 secs into the clip...pause there to understand how it came about by reading the overlaid text.
http://www.youtube.com/watch?v=c8IvttEGLcw
SKYPE ID: rc.650
