Help with Custom Design Character Material
Posted By brothertcoleman 14 Years Ago
brothertcoleman
brothertcoleman
Posted 14 Years Ago
Posts: 578, Visits: 6.1K
Thanks Peter, worked great for Mr Pose ,just need a little more practice with hair segments.
Posted 14 Years Ago
Posts: 23.1K, Visits: 36.6K
Hi..
To be able to change the color and textures of Mr Pose just switch to Skin rather than Upper, Lower etc. Once the Skin tab has been selected you will have access to the Material and Texture Settings.
For the Flowing Hair problem please go HERE for full instructions on attaching the Scalp Base.
The part you seem to be missing is Attaching the Scalp Base to the Layout Base. To do this you need to select the Scalp Base, Right Click and choose Attach. Then select the Layout Base.
Finally you need to select the Attach To button (top right of first image below) and then make sure you have the settings as shown in the second image below. This should do it.
brothertcoleman
brothertcoleman
Posted 14 Years Ago
I follow the directions to try to design character cloths for Mr. Pose but I never get the option to Select the body parts to edit as seen in the picture,the area on the right is not selectable.
Please help also with the Flowing Hair Elements Volume 1.
I think I'm following the steps correctly.
I load the layout base and detach it like the instruction says.
I chose the scalp base but when I load it, it ends up on the ground not on the models head as shown in picture below.
Hair segment ends up way off in the distance as shown in bottom picture.
Not sure what I am doing wrong.
Thanks Tim
