Thanks Peter,
So I open PNG dog image (for example), then face fit. Then go to script>stage>camera and change size and locate where I want image placed. Then go back to model>background settings and insert background. Is there a way to adjust image with background layer in place (for a more accurate placement)? It appears that once the background is set, then I go back to stage>camera that both layers become locked?
When I go back to model, then add background, the image is not reduced and the background is not proportional to the stage view. Then when I return to stage the background doesn't fill frame. Do you have some more tips?
Also, unrelated to above, in face fitting does blue box automatically show up in approximately correct location? It always seems to be in the upper left corner.
After researching past posts, it appears that the best way to do the above is use an outside editor and import my completed image? I thought by doing it within Crazy Talk, with a PNG image, I could eliminate any background distortion when I animate my dog's head. I cannot get the background image to fill the image area!--Jeff
13 Years Ago by
JayBee
