error 19
Posted By Butch Hungo 14 Years Ago
rocketrod
rocketrod
Posted 12 Years Ago
Senior Member (268 reputation)Senior Member (268 reputation)Senior Member (268 reputation)Senior Member (268 reputation)Senior Member (268 reputation)Senior Member (268 reputation)Senior Member (268 reputation)Senior Member (268 reputation)Senior Member (268 reputation)
Last Active: 11 Months Ago
Posts: 2, Visits: 84
Greetings:
I sure could use some help here. I have PopVideo Converter 2 and can't export to the popvideo format. I keep receiving an "Error 19" warning. I don't have Nero codecs installed. I installed the Win7 codec pack you suggested. I'm using Windows 7, 64 bit. Is there anything I can do to make this work? I can export the iWidget just fine and the popvideo export works in CrazyTalk Animator just fine, too.
Any advice you can offer would be most appreciated.
Sincerely,
Rod
Posted 13 Years Ago
Posts: 23.1K, Visits: 36.6K
Jakes (5/14/2012)
Hi There,
Don't want to hijack a thread, but I also have this problem, and already followed the support link above, but no answer yet. I realize it take some time, but I was wondering maybe someone learned something about the error and could help out?
Best regards,
Jakes
Hi Jakes,
The error code 19 can indicate a codec conflict on your computer. Here are some suggestions for you to check.
1. Have you ever installed Nero related software? If so, please follow the steps below to disable the Nero Codec?
http://faq.reallusion.com/index.php?action=article&cat_id=011009002&id=406&lang=
2. Please go to the following site to download Windows codecs and then install.
Win7Codecs:
http://www.majorgeeks.com/Win7codecs_d5959.html
If the suggestion above doesn't resolve this issue, it is recommended you try a video converter tool to convert your source file to WMV format. Then check to see if the problem is resolved.
If you don't have a video converter, you can use the FREE Format Factory.
http://www.formatoz.com/index.html
Jakes
Jakes
Posted 13 Years Ago
Senior Member (431 reputation)Senior Member (431 reputation)Senior Member (431 reputation)Senior Member (431 reputation)Senior Member (431 reputation)Senior Member (431 reputation)Senior Member (431 reputation)Senior Member (431 reputation)Senior Member (431 reputation)
Last Active: 10 Years Ago
Posts: 24, Visits: 84
Hi There,
Best regards,
Jakes
Posted 14 Years Ago
Have you tried uninstalling popVideo Converter and reinstalling?
If this doesn't solve the problem then please contact Reallusion Support using the link below. They will be able to advise you on this error message and how to resolve it.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx
Thanks.
Butch Hungo
Butch Hungo
Posted 14 Years Ago
Veteran Member (745 reputation)Veteran Member (745 reputation)Veteran Member (745 reputation)Veteran Member (745 reputation)Veteran Member (745 reputation)Veteran Member (745 reputation)Veteran Member (745 reputation)Veteran Member (745 reputation)Veteran Member (745 reputation)
Posts: 6, Visits: 103
I can't find a list of errors and meanings and I can't get any output...
