jj61
Group: Banned Members
Last Active: 12 Years Ago
Visits: 195
Hello. I'm french and i use google translate...excuse me for the bad english... I want to animate a firefighter. how to make the pipe? it would have to be attached to one end to the pump and at the other end to a firefighter. while remaining flexible. Is this possible?  Thank for your help
Pompier volontaire utilisateur d'Iclone pour réalliser des vidéos de formations aux sapeurs-pompiers : www.anim18.com
peteradam6
peteradam6
Posted 15 Years Ago
Visits: 1.9K
There is a fire-fighter's hose in the Marketplace for just 300 points. It's not posable, but has an attached water spraying animation:
http://city.reallusion.com/ContentPreview.aspx?i=IC310D154ENU0501A004&g=
Similarly, Ting's Tail (100 points) looks like it could be converted easily to be a fire hose (although possibly it's only a flex prop that can only do constant motion, not poses):
http://city.reallusion.com/ContentPreview.aspx?i=IC300D032ENU0101B006&g=
Or the "Cord A long" prop from the Flowing Hair Elements Sci-Fir pack (100 points) (but, once again, perhaps it's a flex prop that can only do constant motion, not poses):
http://city.reallusion.com/ContentPreview.aspx?i=IC412D040ENU0501D037&g=
| iClone 5 Pro | 3DXchange 4 Pro | popVideo Converter 2 | CrazyTalk 6 Pro | CrazyTalk Animator Pro |
jj61
Visits: 195
Thank for your proposition but... I already tried the fire hose but there was no opportunity to attach to the pump truck. is there no way to simply connect two objects by a prop flex?
Sen
Posts: 2.8K,
Visits: 28.5K
Hi jj (jean-jacques sûrement :P ) click on the link in my signature , french forum :w00t: I will try to help you in your native language , I hope
CGTRADER
jj61
Visits: 195
thank (merci !) i go on imediatly !
Sen
Posts: 2.8K,
Visits: 28.5K
Hi sw00000p , not sure iclone support animated point , rigging point yes
CGTRADER
Cricky
Cricky
Posted 15 Years Ago
Posts: 2.8K,
Visits: 13.8K
jj.fouillard (4/18/2011)
Hello. I'm french and i use google translate...excuse me for the bad english... I want to animate a firefighter. how to make the pipe? it would have to be attached to one end to the pump and at the other end to a firefighter. while remaining flexible. Is this possible?  Thank for your help I had already sent you a message on this, but thought others may be interested. It is possible, and I have proof :P Perhaps some seeing this will recall the Whip I was working on..this is based on the same principle, but more refined, as the Whip was a learning stage in it's creation. But anyway, I will shut-up and yell "FIRE"
SKYPE ID: rc.650
peteradam6
peteradam6
Posted 15 Years Ago
Visits: 1.9K
Excellent. Will this be available for purchase?
Scenes3Dee
Scenes3Dee
Posted 15 Years Ago
Last Active: 15 Years Ago
Visits: 575
Excellent and very well demonstarted Cricky. Great Job :)
jj61
Visits: 195
Exactly what i need ! How can i have this ?
