Spider Mycron
Spider Mycron
Posted 14 Years Ago
Last Active: 8 Years Ago
Visits: 45
Hello i need help with this tutorial please
http://www.youtube.com/watch?v=shFR0owTWTo
when i activate the collision i get no effect ! what shall i do i just created a box and turned collision on but nothing happen !
p.s: maybe iclone version is lower than the video tutorial ?
thanks for help
Posted 14 Years Ago
Posts: 23.1K,
Visits: 36.6K
Hi Spider Are you adding the prop (box) to the Terrain? Just make sure you right click the prop and choose Add To Terrain. Your avatar will not walk through it then. You can find out more about this HERE.
matthew.cownie
matthew.cownie
Posted 14 Years Ago
Last Active: 11 Years Ago
Visits: 149
Peter (RL) (4/13/2011)
Hi Spider Are you adding the prop (box) to the Terrain? Just make sure you right click the prop and choose Add To Terrain. Your avatar will not walk through it then. You can find out more about this HERE. Hi, I've tried both adding collision and adding to terrain and my actor still walks through a solid block. Any ideas? Do you have to be in director mode? EDIT. Doh, yes is the answer!
mjordy
mjordy
Posted 14 Years Ago
Visits: 409
mathew,cownie,
Most avatars in Iclone 4 and 5 will walk through any material and/or geometry(another avatar,animal,car,etc.) one work around this is to plan the walking direction of the avatar slightly off the object(s) in the scene. Clicking on "collision" will not help right away,if it's a "must" for animation purposes to make more believable scenes,then, you have no choice but to use the "block(s),click on collision,and "add to terrain" right click command for the target object or prop.:w00t:
Peter's link above has the best partial solution to this animation problem. But,and just for kicks,the only advantage you can take from this irritating issue is if you're making a movie about "ghosts" they can even walk through people,cars and walls LOL:D
Iclone 4 and 5 rock!
