pam.mccaskill (10/2/2012)
There need to be training on this because as an e-Learning developer, it is quite difficult to follow the instructions without visually seeing an example. We purchased this product because of the transparency and the swf exporting to import in to Adobe Captivate 5.5. Now I learn there are restrictions and additional information on how to achieve what I need, but there isn't any good training. Anything would help like a training doc with screenshots or a quick video. You keep saying to edit using Adobe Premiere, but if someone doesn't know how to use such tools then the product is a waste of our time and resources. What's the difference between png sequence vs png format? How do I create images for png sequence? Photoshop or in CTA? It's confusing and that's why some instructions other than what's being presented need to be created.Hi Pam,
I understand your point about training, but really the training isn't required for CrazyTalk Animator, but instead is needed for whichever video editor you may be using.
So for example, you would export your Sequence Image PNG files from CTA. But once you have exported them, you will need to take them into your chosen video editor for compiling.
If you have been using a video editor for some time, you will probably already know how to do this, but if not, a quick reference of the video editors manual or a tutorial should explain how to do this.
If you let me know which video editor you plan to use, I'll happily point you in the right direction. :)
