shygirl
shygirl
Posted 14 Years Ago
Last Active: 6 Years Ago
Posts: 1.3K,
Visits: 8.3K
Very glad all is now working for you Jason. Thanks for the update. Shy :)
"O wad some Power the gift tae gie us, to see oursels as ithers see us!"
JasonWynngard
JasonWynngard
Posted 14 Years Ago
Visits: 1.2K
Update: Shygirl, I located your other pack (British airman) and got the leather jacket I needed so I'm all set. Did an experimental run and it was fine. Note: The shadowing had to be removed to prevent its overlapping the uniform and giving a weird appearance. But no problem since I'm using the character close up with biplanes and grass field in the background, it's not a problem. Besides, I'm too happy at finding the flight call and goggles as well as a flight jacket accessories to worry about a shadow. Thanks.
Omen HP17t ck00 -- Windows 11 -- 32GB RAM -- Two 1TB Crucial M.2 NVME Drives -- nVidia Geoforce RTX 3070 -- 11th Generation i9 -- LG 32" QUHD Monitor
JasonWynngard
JasonWynngard
Posted 14 Years Ago
Visits: 1.2K
Shy, your suggestion (no hair) worked perfectly. AND I located the uniforms. i had to hunt them but suspect it is due to my lack of mastery of iClone. They don't appear in the accessory list inside the program. But Windows 7 allows a swift search and drag and drop so I think I'm pretty happy. The only thing is the only leather jacket is the Japanese one so will use PSP to get rid of the red and white insignia.
Cricky
Cricky
Posted 14 Years Ago
Posts: 2.8K,
Visits: 13.8K
JasonWynngard (3/24/2011)
Yes, it is the style I seek. Actually I have a front and back photo of this type. My real question is how to convert it into an accessory for iClone. To convert something like that to an accessory, you'll 1st need a mesh it can be applied to...the rest is all about getting the texture to fit that mesh. There are only a few programs out there that can wrap a texture to a mesh, but it would also take flattening the mesh to allow the texture to be applied. It's always easier when you have a mesh that can be fitted or painted with an existing texture. Good Luck...
SKYPE ID: rc.650
JasonWynngard
JasonWynngard
Posted 14 Years Ago
Visits: 1.2K
Shy, I believe this is the one I mean. That's the Japanese outfit isn't it. In any case your common sense comment about removing the hair may be exactly what I need to do (DUH), thanks for very likely saving my nitwit rear.
JasonWynngard
JasonWynngard
Posted 14 Years Ago
Visits: 1.2K
Machines of War, I will look into that. THANKS!
JasonWynngard
JasonWynngard
Posted 14 Years Ago
Visits: 1.2K
Cricky
Cricky
Posted 14 Years Ago
Posts: 2.8K,
Visits: 13.8K
I edited the Tank Commanders Helmet to allow it to have the Goggles drop over his eyes and return back up... But it does belong to Reallusion, so you would likely need their pack to use it as I'm sure the DRM carries forward. This Image is animated, so if you want to see the animation, either your browser has to allow the animation, or you'll have to download and view it separately. It works in Firefox, but it's been so long since I used IE (Internet Excuse) that I couldn't tell you if that works or not.
shygirl
shygirl
Posted 14 Years Ago
Posts: 1.3K,
Visits: 8.3K
Hi Jason, I'm not quite sure which pack you refer too as I made several WW packs, all of which were some time ago......and the memory ain't what it used to be. :P I have enclosed a pic of the Aviator helmet which I am assuming you refer to, please correct me if I am wrong. I removed the hair from the character as you don't see it because the helmet covers the entire head anyway and the helmet fits fine. Please let me know if it is a different character and I will do my best to help.
regards Shy
Cricky
Cricky
Posted 14 Years Ago
Posts: 2.8K,
Visits: 13.8K
