Dreamcube017 (3/17/2011)
If you mean the images in the image viewer, I think it's just saved in a temp directory somewhere. You can always just save it for editing purposes manually.
And yeah that pose snapshot would be sweet.Hi DC, no, fortunately, iClone remembers the last folder you used, so it's definitely saved in place favorable to the user. What I am asking for is a way to avoid having to navigate the filesystem at all.
To be fair, there is already a dirty trick you can use to avoid navigating the filesystem.
1. After iClone exports your still image to the most-recently-used folder, click Export again.
2. When the Save As dialog appears, you can right-click the name of the still image that you just saved.
3. Choose Open from the context menu, and this sends the image to your picture editor.
4. Cancel the Save As dialog, since the dirty trick has fooled iClone into finding your picture for you.
I am asking for a way to avoid the dirty trick.
General Picture - animating now to life itself(tm)
Member of Content Wizards
