What are the video format import limitations?
Posted By gordoTalk 15 Years Ago
3
scruff dog
scruff dog
Senior Member (479 reputation)Senior Member (479 reputation)Senior Member (479 reputation)Senior Member (479 reputation)Senior Member (479 reputation)Senior Member (479 reputation)Senior Member (479 reputation)Senior Member (479 reputation)Senior Member (479 reputation)
Posts: 32, Visits: 62
I know this is an old thread, but worth a shot.
When I import a MOV as a prop it keeps looping. Do you know how I stop that? What controls over the video do I have?
Thanks.
carlosegs
carlosegs
Last Active: 6 Years Ago
Posts: 44, Visits: 172
Hi,
With the release of CTA3, was there any improvement to support (a) video formats with alpha (other than popvideo) and (b) gif files? Or these functionalities are still missing?
Thanks,
Carlos
Posted 12 Years Ago
Posts: 23.1K, Visits: 36.6K
josephtavenner (1/2/2013)
In one of the early questions on this thread it asks if you can start and stop an imported video.  I have a problem where it just wants to run in a loop and not stop.  Anyone know how to start and stop an imported video?
By default videos will always loop.
If you just want the video to play through once, open the timeline and select the Visible track for the video. Move to the end of the video and then use the Show/Hide button from the top toolbar.
Hope this helps.
josephtavenner
josephtavenner
Posted 12 Years Ago
Last Active: 12 Years Ago
Posts: 1, Visits: 2
Posted 13 Years Ago
gordoTalk (12/7/2012)
[b]Peter (RL)
Using .avi files with alphaisn't supported unfortunately.
Video formats supported (without alpha) are avi, wmv, mpg, mpeg, mpe, mov, swf.
Hope this helps a little. :)
Hi Peter,
It's been a while. Does Animator support video formats (other than popvideo) with alpha yet?
Unfortunately there have been no further updates to CTA since your original request. Currently CrazyTalk Animator 2 is in development and we should have more information to share soon on this.
gordoTalk
gordoTalk
Posted 13 Years Ago
Last Active: 13 Years Ago
Posts: 85, Visits: 155
[b]Peter (RL)
Hi Peter,
Posted 14 Years Ago
studio755 (4/13/2011)
My version (1.1.1516) doesn't seem to want to accept any video codecs except WMV . Have been trying to get output from Particle Illusion into CTA. I am surprised it won't even accept an uncompressed avi with alpha. Read the post about "power of 2" and encoded videos to suit, even re installed CT. but to no avail. I would have thought this was an important part of video creation.
Sorry to hear of your frustration. Since the improvements made in the v1.1 upgrade you do have the option to use .swf or .popVideo format with transparent background. Using .avi files with alpha isn't supported unfortunately.
And just to clarify, the "Power of 2" error message is only an issue with certain older graphics cards. If you have not recieved this error message then you my advice regarding this will not affect you.
So just to be clear about your post you require me to buy another of your programs to enable transparent video import into CTA and add another layer to the workflow?
You certainly don't have to purchase popVideo Converter and can use .swf if you wish as an alternative. Personally I would recommend using popVideos for video use because they are so easy to use and shouldn't cause any compatibility issues.
Perhaps you should mention this before people press the buy button.or at the very least take the "PRO" off the name.
I don't believe there has been any advertising claiming that video with transparency such as avi can be used in CTA but I can understand you are unhappy about this not being possible. Please let us know if you have seen anything misleading regarding using video with alpha channel and it will be corrected. Video formats supported (without alpha) are avi, wmv, mpg, mpeg, mpe, mov, swf.
studio755
studio755
Posted 14 Years Ago
Last Active: 14 Years Ago
Posts: 1, Visits: 23
"If you want to import video with a transparent background then I'm afraid you will need to use popVideos as this is the only supported format for drag and drop into your scene."
However if you have iClone for example you can export popVideos directly from this which can be opened in CTA without you needing to own popVideo Converter itself.
Regards
Paul
Posted 14 Years Ago
gordoTalk (12/23/2010)
Presumably Animator will import video content generated by Reallusions other products in the *.iWidget and *.popVideo formats. Unfortunately it's looking to me that .mov files with alpha channel are not supported. So I'd like to confirm what is supported first.
Just to add that while the video formats you have mentioned are not currently supported with alpha channel you do have another option which is to use SWF if you are able to work in this format. This is another option if you don't want to use popVideos.
Paumanok West
Paumanok West
Posted 14 Years Ago
Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)
Last Active: 11 Years Ago
Posts: 2.5K, Visits: 7.0K
Peter (RL) (1/25/2011)
gordoTalk (1/25/2011)
Hopefully the transparency limitation for videos coming from non-Reallusion products will be removed in the next minor update.
Your product manager needs to re evaluate this decision. By refusing transparent assets this drastically limits CTA's role in creating a basic video, or even a scene.
I really don't think this is a deliberately imposed limitation as you suggest. I'm sure the development team will be lookingto add further supportfor video formats with alpha in the future.
I'm glad to hear this. I haven't been following the user feedback on CTA very closely, but I think gordo has made a good case for the need for CTA to behave like the other video tools he is used to using.
In iClone, this functionality is provided by an opacity channel for an object, where it works well. What's the chance this opacity channel functionality could be ported over quite literally?
General Picture - animating now to life itself(tm)
Member of Content Wizards
3
