.DDS File Format Support
Posted By davidjosue007 16 Years Ago
colour
colour
Posted 14 Years Ago
Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)
Posts: 5.2K, Visits: 8.1K
It's the % of Total Memory you should be looking at (See my Screenshot), not % of CPU usage, together with the iClone Kb usage (See my Screenshot) & the number of Running Processes.
From my Screenshot, you'll see that my Total Memory usage is 37% with 44 Running Processes.
I have 6GB RAM.  iClone is taking-up approximately 1GB of that. So I have plenty of spare RAM capacity.
I have a 64Bit OS, & since iClone will access upto 4GB RAM with a 64Bit OS, I could in theory Import a number od additional Objects into my Project.
If you have a 32Bit OS, iClone will access upto 2GB RAM. If I Opened my Project in iClone 32Bit Version, I would still have 1GB spare RAM.
If iClone is stating that you have insufficient RAM, you could end some non-essential Running Processes, to Free-up additional RAM. There's a Free Download Program; Enditall, that will automatically do that for you (But you would use it at your own risk). I don't have it, because I don't need it, with the System in my signature. Those with a marginal System, do.(IMO, your System is marginal, especially the CPU & amount of RAM, which "Could" be the cause of your problem).
The above is a brief description of the processes involved.
I'm afraid I can't give you  precise instructions re; hoew to Fix your particular Problem. Reallusion's Forum Rep; Peter Edwards might. Send him a PM, referring your Thread.
Good luck :)
Anyone-else?
Pochontas
Pochontas
Posted 14 Years Ago
Last Active: 8 Years Ago
Posts: 65, Visits: 128
hmm how come every time I import a mesh with a tree the tree doesn't make it (it looks like a green mist) so I have to remove it from 3dxchange. Is there perhaps some trick I could do to have those trees?
wendyluvscatz
wendyluvscatz
Posted 14 Years Ago
Senior Forum Member
Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)
Last Active: 6 Months Ago
Posts: 2.5K, Visits: 19.4K
is 2 sided checked in materials?
also look at the opacity map or if it uses a png
I found converting dds to png with transparancy rather dodgey using irfanview
a seperate alpha/opacity map works better.
Pochontas
Pochontas
Posted 14 Years Ago
I use DDS converter 2 for converting .dds to .jpg.
But do you also get sometimes meshes bent? Like the Leaning Tower of Pisa?
I usually try to re-strech it in x,y,z scale and sometimes it works but sometimes it doesn't.
