.DDS File Format Support
Posted By davidjosue007 16 Years Ago
Pochontas
Pochontas
Posted 14 Years Ago
Last Active: 8 Years Ago
Posts: 65, Visits: 128
I use DDS converter 2 for converting .dds to .jpg.
But do you also get sometimes meshes bent? Like the Leaning Tower of Pisa?
I usually try to re-strech it in x,y,z scale and sometimes it works but sometimes it doesn't.
wendyluvscatz
wendyluvscatz
Posted 14 Years Ago
Senior Forum Member
Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)
Posts: 2.5K, Visits: 19.4K
is 2 sided checked in materials?
also look at the opacity map or if it uses a png
I found converting dds to png with transparancy rather dodgey using irfanview
a seperate alpha/opacity map works better.
Pochontas
Pochontas
Posted 14 Years Ago
hmm how come every time I import a mesh with a tree the tree doesn't make it (it looks like a green mist) so I have to remove it from 3dxchange. Is there perhaps some trick I could do to have those trees?
colour
colour
Posted 14 Years Ago
Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)
Posts: 5.2K, Visits: 8.1K
It's the % of Total Memory you should be looking at (See my Screenshot), not % of CPU usage, together with the iClone Kb usage (See my Screenshot) & the number of Running Processes.
From my Screenshot, you'll see that my Total Memory usage is 37% with 44 Running Processes.
I have 6GB RAM.  iClone is taking-up approximately 1GB of that. So I have plenty of spare RAM capacity.
I have a 64Bit OS, & since iClone will access upto 4GB RAM with a 64Bit OS, I could in theory Import a number od additional Objects into my Project.
If you have a 32Bit OS, iClone will access upto 2GB RAM. If I Opened my Project in iClone 32Bit Version, I would still have 1GB spare RAM.
If iClone is stating that you have insufficient RAM, you could end some non-essential Running Processes, to Free-up additional RAM. There's a Free Download Program; Enditall, that will automatically do that for you (But you would use it at your own risk). I don't have it, because I don't need it, with the System in my signature. Those with a marginal System, do.(IMO, your System is marginal, especially the CPU & amount of RAM, which "Could" be the cause of your problem).
The above is a brief description of the processes involved.
I'm afraid I can't give you  precise instructions re; hoew to Fix your particular Problem. Reallusion's Forum Rep; Peter Edwards might. Send him a PM, referring your Thread.
Good luck :)
Anyone-else?
Pochontas
Pochontas
Posted 14 Years Ago
OK, my specs are: Win 32 bit
2,00 gigahertz Intel Core 2 Duo
64 kilobyte primary memory cache
2048 kilobyte secondary memory cache
64-bit ready
Multi-core (2 total)
Not hyper-threaded
Board: Gigabyte Technology Co., Ltd. G31M-ES2L
ATI Radeon HD 5600 Series
Bus Clock: 200 megahertz
HDD is 1TB + 250 GB
RAM
3072 Megabytes Usable Installed Memory
Slot 'A0' has 2048 MB
Slot 'A1' has 1024 MB
I also watched CPU percentage during the run of Iclone and it usually doesn't climb over 10% but if I put some character that moves then it goes up to something like 22%
I also watched CPU during the opening of .3dr file in 3dsMAX and it doesn't go higher then 50% even when it comes to the point when it says that application doesn't have enough memory (it usually loads 66% of the file when that happens). I also monitored Commit Charge and it climbs while he's trying to load it up to 2313/4445M when it crashes.
colour
colour
Posted 14 Years Ago
Pochontas (9/13/2012)
Yeah funny you mention it because I recently ripped what it seems to be a huge file. I usually open .3dr in 3dsMAX (because .obj files made by 3Dripper seem to be messed up) and this one I can't open because during the opening process I get "not enough memory" message. What kind of memory is it talking about? And what can I do to open it?
Your PC's RAM (Random Access Mermory).
Right-Click on your PC's Desktop Taskbar. Select Task Manager in pop-up. Select Processes Tab. Check the Total % of RAM usage (Bottom left). Also check Memory usage for iClone /3DXchange?
Programs on a 32 Bit OS access upto 2GBs RAM. 64 Bit; upto 4Gb RAM, depending upon the Total RAM Installed & how many other Programs you have Running.
If iClone / 3DXchange? are approaching their Total RAM limit & your Imported Object goes over that limit, you'll run-out-of RAM.
That being said, your PC can grab additional Virtual Memory from the HDD, which is very slow. That's why more RAM is better than less.
That's a simple explanation, but there are exceptions.
Anyone-else?
Pochontas
Pochontas
Posted 14 Years Ago
wendyluvscatz
wendyluvscatz
Posted 14 Years Ago
Senior Forum Member
you need to tick the box that says two sided
for each mesh
pity one cannot do this on all meshes at once without using affect all materials and selecting all which is no good if different colours used.
(one thing 3dx2 DID do!)
Pochontas
Pochontas
Posted 14 Years Ago
wendyluvscatz (9/7/2012)
and since for some odd reason I cannot edit my post
I forgot to add I edited the mtl with plain old notepad
it will find and replace all .dds with .jpg in one click!
hey, just realized this thread is 2 years old! :w00t:
Thank you!
Just one problem. It's irritating but it has a lot of objects and some of them don't look as whole in 3dxchange. For instance some cubical objects look like they're just an upside "L" but when I rotate them then all of a sudden sides that didn't seem to be there suddenly appear and sides that were visible dissapear. Does anyone know what to do to see them all?
wendyluvscatz
wendyluvscatz
Posted 14 Years Ago
Senior Forum Member
