Saving Poses
Posted By funfunfun 16 Years Ago
funfunfun
funfunfun
Posted 16 Years Ago
Last Active: 10 Years Ago
Posts: 204, Visits: 769
Hello,
I'm interested in learning more about copying and saving poses from the Motion Layer track.
Can one isolate a pose from a motion on the timeline, and how? I want to isolate one pose (frame), and save it for later, or copy it to another location on the timeline.
Similarly, if I pose the face on the Facial Layer, can I save that keyframe (facial pose) and load it onto another character in another scene?
Finally, are there static poses pre-built that I can drag and drop like in Poser?
Thanks.
Paumanok West
Paumanok West
Posted 16 Years Ago
Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)
Last Active: 12 Years Ago
Posts: 2.5K, Visits: 7.0K
funfunfun (9/3/2010)
(A) Can one isolate a pose from a motion on the timeline, and how? I want to isolate one pose (frame), and save it for later, or copy it to another location on the timeline.
(B) Similarly, if I pose the face on the Facial Layer, can I save that keyframe (facial pose) and load it onto another character in another scene?
(C) Finally, are there static poses pre-built that I can drag and drop like in Poser?
(A) There is no special feature for making it quick and easy to save a pose. I have submitted this as a feature request, but I never heard whether RL is committed to implementing it. It would be quite valuable to have and it should be extremely easy for the programmers to implement. To do this manually, you have to use the break-track button to snip away either side of the pose.
(1) Open your Timeline.
(2) Display the motion track for your selected avatar.
(3) Position the cursor to one side of the desired pose, click the motion track to activate it, and click the break-track button.
(4) Repeat step 3 on the other side of the pose.
(5) Move the broken tracks out of the way.
(6) Click the Collect Clip tab.
(7) Drag inside the Collect Clip track to capture the pose.
(8) Right-click on the Collect Clip track and Save to Library.
(B) I suspect the same procedure can be applied to a Face track.
(C) iClone comes with some static poses in the animation folder. You can purchase a few more from the Content Store.
General Picture - animating now to life itself(tm)
Member of Content Wizards
Teviniii
Teviniii
Posted 16 Years Ago
Posts: 543, Visits: 3.7K
The simplest way to freeze a pose and to subsequently save it, is to "Remove All Animation" at the point on the timeline where the desired pose appears.  You would then use "Collect Clip" to capture the pose.
Paumanok West
Paumanok West
Posted 16 Years Ago
Teviniii (9/3/2010)
The simplest way to freeze a pose and to subsequently save it, is to "Remove All Animation" at the point on the timeline where the desired pose appears.You would then use "Collect Clip" to capture the pose.
Dang it, he's right.
On the other hand, the drawback of his method is you'd better have your project saved first--because you must reload it to capture ANOTHER pose.
funfunfun
funfunfun
Posted 16 Years Ago
Thank you for the answers! Are you saying that after you click "Remove All Animation" from the popup, that it will remove everything except the one frame that you are on? Why doesn't it remove that too and return the figure to straight up and down?
Also, In order to capture a facial pose, will this work with the facial layer just the same?
funfunfun
funfunfun
Posted 16 Years Ago
Bump,
