difference between CT5Pro and CT Media Studio edition
Posted By anndee 18 Years Ago
anndee
anndee
Posted 18 Years Ago
Veteran Member (537 reputation)Veteran Member (537 reputation)Veteran Member (537 reputation)Veteran Member (537 reputation)Veteran Member (537 reputation)Veteran Member (537 reputation)Veteran Member (537 reputation)Veteran Member (537 reputation)Veteran Member (537 reputation)
Last Active: 15 Years Ago
Posts: 82, Visits: 728
Eliza, as I see now, that there is a human beeing interested in it, I will continue - and if its only for you :)
Andi
PS: Meine Erfahrungen mit der Einarbeitung in iClone in deutscher Sprache in meinem Blog.
eliza.skywalker
eliza.skywalker
Posted 18 Years Ago
Veteran Member (677 reputation)Veteran Member (677 reputation)Veteran Member (677 reputation)Veteran Member (677 reputation)Veteran Member (677 reputation)Veteran Member (677 reputation)Veteran Member (677 reputation)Veteran Member (677 reputation)Veteran Member (677 reputation)
Last Active: 13 Years Ago
Posts: 113, Visits: 222
@Andi: I hope you continue your blog. I just had a look at it.
anndee
anndee
Posted 18 Years Ago
( although I fear I may have confused you more :doze: )
Hi, Pete. No you havn`t confused me, I understand it now with Crazy Talk.
And thanks for your support with element 5. I hope, that I get the add-ons finally to begin to work with iClone.
Andi
Posted 18 Years Ago
Posts: 23.1K, Visits: 36.6K
a.b.dauer (7/22/2008)
Thanks RKD for your posting. So I hope to understand right, that I use CT5Pro for using alone ( as a seperate program out of iClone ) and CT5 Media Studio Edition for working integrated in iClone and must by this reason install both versions....
Hi Andi,
I'll try and clear things up for you. When Crazytalk 4 was upgraded to Crazytalk 5 the name Media Studio was replaced by the term Pro. So the latest version is Crazytalk 5 Pro and the name Media Studio is no longer used.
The problem RKD was referring to was that iClone 2.5 will not work with Crazytalk 5 scripts and so to share scripts between those two products requires Crazytalk 4 Media Studio Edition be installed as well as Crazytalk 5 Pro. iClone 3 will be compatible with Crazytalk 5 when it is released next month.
I hope this clears things up. ( although I fear I may have confused you more :doze: )
anndee
anndee
Posted 18 Years Ago
Andi
RKD
RKD
Posted 18 Years Ago
Posts: 178, Visits: 2.7K
CrazyTalk 5 Pro is the successor of CrazyTalk 4 Media Studio Edition.
EDIT: The latter is maybe needed because iClone 2 does not support CrazyTalk 5.
anndee
anndee
Posted 18 Years Ago
Hi, I own Power Bundle Pack II Pro and have there two Crazy Talk versions: CT5Pro and CT Media Studio Edition, but cannot figure out the difference between these two versions or if I need both versions for working.
Can anybody explain it to me, as I not found the answer in the FAQs.
Thanks,
Andi
Andi
