a.b.dauer (7/22/2008)
Thanks RKD for your posting. So I hope to understand right, that I use CT5Pro for using alone ( as a seperate program out of iClone ) and CT5 Media Studio Edition for working integrated in iClone and must by this reason install both versions....Hi Andi,
I'll try and clear things up for you. When Crazytalk 4 was upgraded to Crazytalk 5 the name Media Studio was replaced by the term Pro. So the latest version is Crazytalk 5 Pro and the name Media Studio is no longer used.
The problem RKD was referring to was that iClone 2.5 will not work with Crazytalk 5 scripts and so to share scripts between those two products requires Crazytalk 4 Media Studio Edition be installed as well as Crazytalk 5 Pro. iClone 3 will be compatible with Crazytalk 5 when it is released next month.
I hope this clears things up. ( although I fear I may have confused you more :doze: )
