Posted Last Year
Posts: 15.8K,
Visits: 31.4K
The error message seems to be for DX9, which is not directly supported, it seems. Regular DX12 is already installed. However, I found this link: https://www.microsoft.com/en-ie/download/details.aspx?id=8109, which installs addionally components for legacy DX9, which you should not need for iClone, I think. EDIT: Peter was quicker...:w00t:
Posted Last Year
Posts: 23.1K,
Visits: 36.6K
The error message indicates an issue with DirectX 9 which is not compatible with iClone 8. The problem may be that you do not have the correct graphics drivers installed. Try going to the Nvidia website and install the correct graphic drivers for the RTX 4090 and Windows 11. If you still get errors after that, try uninstalling DirectX 9 as there may be some corrupt files causing the errors.
Last Active: 6 Months Ago
Visits: 169
Bug that seems to only impact newest computers (had an Alien i7 computer, besides needing more memory, iclone worked fine) = help desk unstable to find a solution. // [255483] Support Response: error code 0xc000012f New computer bought on Amazon: Panorama Gaming PC (GeForce RTX 4090, Intel 24-Core i9-14900KF CPU, 192GB DDR5 RAM, 4TB Gen4 990 Pro SSD + 12TB HDD, WiFi 6E, W11 Pro) Best 2024 Prebuilt RGB Tower Desktop Computer for Gamers. ///// Originally thought it was a simple update of DirectX - but after update load of program still failed, but with new new error: /// message 0xc000012f. Systems32\d3dx9_43.dll is either not designed to run on Windows or contains an error. //// Trying installing the program again using original installation media or contact your systems administrator or the soft3ware vendor for support //// reported to iclone via ticket [255483] Support Response: error code 0xc000012f on Oct 6, have not received any follow up reply. Posting warning on Amazon to this computer warning of possible but of computer.
https://www.amazon.com/dp/B0D47ZMRYH?ref=ppx_yo2ov_dt_b_fed_asin_title
