fchentoronto
fchentoronto
Posted Last Year
Visits: 7
Just brought Cartoon Animator 5, it asked to install the Reallusion Hub on my Window 11. I clicked on installation file, saw the progress bar moved When the the installation window disappeared, I thought the installation was completed. But Nothing happens after the progress bar disappered. The Reallusion Hub didn't show. I could not find the Reallusion Hub at all. I searched "Add or Remove Program" under Settings, I couldn't find the Reallusion Hub. Please help.
Posted Last Year
Posts: 23.1K,
Visits: 36.6K
Hi... You can check if the Reallusion Hub is installed by clicking on Start > All Apps and then scroll down to the R section (Windows 10/11). If it is not there, then please download again from the page below and save the installer to your computer. Then right click the downloaded file "Reallusion_HUB_Lite.exe" and choose "Run As Administrator". This should install the Hub successfully on your computer. https://www.reallusion.com/hub/
fchentoronto
fchentoronto
Posted Last Year
Visits: 7
I followed your instructions, it doesn't work. I right click to choose "Run As Administrator". Still the same, I don't see the apps under "R" section in all apps. Saw the progress bar showing it was installing, but it disappeared and no program showing up.
Posted Last Year
Posts: 23.1K,
Visits: 36.6K
Please take a look at the FAQ page below where you will find various things to try including downloading a different (full) installer. However, if the problem continues, I would advise contacting Technical Support using the link below. They will be able to advise you further. https://kb.reallusion.com/General/1243
narayankumawat89089
narayankumawat89089
Posted Last Year
Last Active: 8 Months Ago
Visits: 38
Hello sir, Sir, when I try to install Reallussion hub in my pc this error occurs " Network error - proxy, PAC, or other error, set-up has encountered a connection error " But i have good network speed and still i installed in my pc but when i open Reallussion hub it doesn't show anything completely empty Please help me sir what do I do π
Posted Last Year
Posts: 23.1K,
Visits: 36.6K
narayankumawat89089 (11/19/2024) Hello sir, Sir, when I try to install Reallussion hub in my pc this error occurs " Network error - proxy, PAC, or other error, set-up has encountered a connection error " But i have good network speed and still i installed in my pc but when i open Reallussion hub it doesn't show anything completely empty Please help me sir what do I do πIf the information in the FAQ doesn't help, then as I mentioned in my previous reply, please contact Technical Support (link below). They will help you. https://www.reallusion.com/CustomerSupport/UserEx/QForm.html
