Reallusion Hub is not installing on my computer
https://forum.reallusion.com/Topic556502.aspx
Print Topic | Close Window
By fchentoronto - 2 Years Ago
Just brought Cartoon Animator 5, it asked to install the Reallusion Hub on my Window 11.  I clicked on installation file, saw the progress bar moved  When the the installation window disappeared, I thought the installation was completed.  But Nothing happens after the progress bar disappered.  The Reallusion Hub didn't show.  I could not find the Reallusion Hub at all.  I searched "Add or Remove Program" under Settings, I couldn't find the Reallusion Hub.   Please help.
By Peter (RL) - 2 Years Ago
Hi...
You can check if the Reallusion Hub is installed by clicking on Start > All Apps and then scroll down to the R section (Windows 10/11).
If it is not there, then please download again from the page below and save the installer to your computer. Then right click the downloaded file "Reallusion_HUB_Lite.exe" and choose "Run As Administrator". This should install the Hub successfully on your computer.
https://www.reallusion.com/hub/
I followed your instructions, it doesn't work.  I right click to choose "Run As Administrator".  Still the same, I don't see the apps under "R" section in all apps.  Saw the progress bar showing it was installing, but it disappeared and no program showing up.
Please take a look at the FAQ page below where you will find various things to try including downloading a different (full) installer.
However, if the problem continues, I would advise contacting Technical Support using the link below. They will be able to advise you further.
https://kb.reallusion.com/General/1243
By narayankumawat89089 - 2 Years Ago
Hello sir,
Sir, when I try to install Reallussion hub in my pc this error occurs " Network error - proxy, PAC, or other error, set-up has encountered a connection error "
But i have good network speed and still i installed in my pc but when i open Reallussion hub it doesn't show anything completely empty
Please help me sir what do I do 😭
narayankumawat89089 (11/19/2024)
Hello sir,
If the information in the FAQ doesn't help, then as I mentioned in my previous reply, please contact Technical Support (link below). They will help you.
