Hello,
I'm sorry, but I don't think I fully understand what I should do exactly (unfortunately I'm still inexperienced with iClone)
Currently I'm using CC3 characters and Rokoko's animation
When exporting from Rokoko, I can choose between the following export options
HumanIK, Mixamo, iClone
However, they all look the same to me.
Which one should I use?
I've now used HumanIK
First I dragged and dropped the animation into iClone.
Then transferred my customized CC3 character and assigned the previously converted animation via 3DXChange (with Export Geometry).
I use this setting. Is that right?
Then I reset both with (Reset Zero Out).
Then it looks like this:
It doesn't match like it did for you.
How do I get that fixed?
But if I understood it correctly, it should look like this:
Correct this manuelly.
Frame 7 looks like that
"However, if the dummy's torso does NOT match at all, you will need to repeat the bone mapping. You may have missed a spinal bone."What exactly do I have to do? And where exactly can I do that?
Unfortunately I don't know how and where to do the retargeting!
Where do I actually get the dummy character so that it looks exactly like the prop?
Best regards
Stephan
