toystorylab
toystorylab
Posted Last Year
Posts: 4.6K,
Visits: 29.9K
Interesting! When I got it right, no camera setup needed at all? Just strap those thingees and record wherever you are and no matter how much space you have? I assume sitting on chair works fine too?
Toystorylab on Vimeo : 75% of original size (was 671x19) - Click to enlarge Crassitudes (my "Alter Ego") on Youtube: 75% of original size (was 671x19) - Click to enlarge
mtakerkart
mtakerkart
Posted Last Year
Posts: 3.2K,
Visits: 29.2K
toystorylab (10/21/2024)
Interesting! When I got it right, no camera setup needed at all? Just strap those thingees and record wherever you are and no matter how much space you have? I assume sitting on chair works fine too? Indeed there is no need to film. The iPhone is used to record the mocap via Bluetooth, so if you wear it on you there is no limit to the movement. In addition I find the hardware very solid and really easy to implement.There is also a function to block the hip for the sitting position but I did not use it in my test and the result is very acceptable.
