AutoDidact
AutoDidact
Posted Last Year
Posts: 2.1K,
Visits: 13.6K
The import process into UDK showed by JSFILMZ required NASA engineer skills which required PC and wifi to stream data.
LOL!! :DI really do not get why people insist that unreal engine is a good choice for animated filmmaking with Characters What the hell good is “realtime” when you have to do 15 complicated steps before your Character can even start moving.
mtakerkart
mtakerkart
Posted Last Year
Posts: 3.2K,
Visits: 29.2K
I will give a try next week with the dual camera Rokoko vision. There's a 14 days trial. Let's see what it gives... https://www.rokoko.com/products/vision
WesleySales3d
WesleySales3d
Posted Last Year
Visits: 267
For single-camera mocap solutions, I recommend:
- Move One mobile app
- Animcraft (This also cleans up foot contact and retargeting directly to the Iclone skeleton).
- Quickmagic.ai website
I don't like Rokoko's camera-based solutions, I think they're too weak in terms of precision and it'll take a lot more work to adjust everything manually. Not to mention that the 2-camera version needs calibration.
jeffkirkland
jeffkirkland
Posted Last Year
Last Active: 8 Months Ago
Visits: 1.7K
sunnyviewtech (9/2/2024)
With our monocular camera-based motion capture software, Dollars MONO, you can also capture motion in real-time from a camera or video file and transfer the motion capture data to iClone. We also support facial and finger capture.I like Dollars MONO enough to spend money on it Its live link to iClone makes it very convenient for some quick motion capture but I tested them side by side and Meshcapade's mocap gave a much more accurate result, in terms of figuring out occlusion although everything I've tried in Meshcapcade tends to be off the ground and leaning forward.
Jeff Kirkland | Director • Cinematographer • Storyteller Hobart • Tasmania • www.one18films.com SYSTEM: AMD Ryzen 5 5500 | 32gb RAM | RTX 3060 12gb | 1tb SSD System | 44tb HDD Storage
mtakerkart
mtakerkart
Posted Last Year
Posts: 3.2K,
Visits: 29.2K
I did a single test with the rokoko vision and it is what I found most precise in the placement of the feet. There are still strange movements. I bought the webcams that they recommend but it requires a distance of 11 feet!! So if you have to act in a square of 8X8 feet you need a room of 20X20 feet!!! I will do a test again Friday in a larger room. It is imperative to have a PC (not strong), an internet connection and print the documents to calibrate the cameras.
sunnyviewtech
sunnyviewtech
Posted Last Year
Visits: 473
Thank you, sir. We are continuously improving the capture quality.
mtakerkart
mtakerkart
Posted Last Year
Posts: 3.2K,
Visits: 29.2K
Ok guys , back to the topic. Something cool might happen ...
I tried the Rokoko Vision the 2 cameras advised by rokoko. Clearly not usable. And as I said it need very large set to be entirely seen by the cameras.
Tested Move.AI this morning (Yes It's a Christmas pant :P ) and very very happy with this tech. Only one Iphone and no root drift or strange behavior. The feet need a very little tweak but I'm sure that 2 Iphones will solve this defect. This is RAW data.
mtakerkart
mtakerkart
Posted Last Year
Posts: 3.2K,
Visits: 29.2K
Hehehe ! me again :P
I get the mocopi mocap system and pleasantly surprised by the quality of the mocap. The video below is a raw bhv file and very easy to import. I get better result as the neuron suit V1 and rokoko.
Kalex
Visits: 6.5K
Hey ! Never heard about mocopi. Is it some mocap solution that allows to capture a motion from video ?
You might be interested by this also. I have no idea when they plan to release it though.
mtakerkart
mtakerkart
Posted Last Year
Posts: 3.2K,
Visits: 29.2K
Kalex (10/21/2024) Hey ! Never heard about mocopi. Is it some mocap solution that allows to capture a motion from video ?
Mocopi is this : https://electronics.sony.com/more/mocopi/all-mocopi/p/qmss1-uscx?srsltid=AfmBOoolG-u89KJgKKvJhQAuiAvcvwTqiZEmgj7cz0a2-5mvbc4L20p0Yes, I had seen the Microsoft project but it is a prototype and is not accessible at the moment ;)
