ccondenser
ccondenser
Visits: 40
Well, In our case the issue was rather silly - the character was just locked in scene outliner :blush:
Terry Miller
Terry Miller
Last Active: 5 Months Ago
Visits: 2.2K
By the way, in case they don't answer, here is what I had to do to attach the prop. Select the character, and open Edit Reach Target. Select the hand you want to attach the prop to, and create a dummy. Then parent the dummy to the hand. Finally, select the prop and parent it to the hand dummy. That was the only way I could get that prop to attach or link to the character.
Terry Miller
Terry Miller
Visits: 2.2K
Ummm... So, what is the solution to this problem? I am having the same issue, but I don't want to use Kevin, I want to use the character I created. (BTW, it was created from the Toon Neutral Male, with just morphs applied to it, no zBrush, or anything like that.) Anyway, I cannot get a prop to link or attach to it.
ccondenser
ccondenser
Visits: 40
Thanks for the reply. Just checked, no such problem with Kevin.
Posts: 23.1K,
Visits: 36.6K
Have you tried with one of the embedded characters like Kevin. Do you still have the same problem?
ccondenser
ccondenser
Visits: 40
Hello. What could be the problem if I can't select a character to link a prop to him? CC3+ character was modified by ZBrush Face Tool. I can link and "look at" prop to anything in scene, but the character is invisible for it.
