I imported the 'Toon Neutral_F' base character into Character Creator 4 using the 'Create Character' button and started making basic adjustments to the body and face.
Then I exported it into ZBrush using the amazing new GoZ Plus plugin with one simple click. You can check it out here
Character Creator GoZ Plus for ZBrushThen it quickly showed in my ZBrush and I started masking to create a skull similar to the reference pics.
Then I decided to make it with a sphere and used the 'SnakeHook' Brush to shape it as the picture below
Here I started masking areas for eyes and horns using the 'MaskLasso'
Then I made a cut to those areas and moved them up the skull, added two spheres for the eyes, and tested some horns
Then I worked more on it
Last Month by
mazouzi.khaled
