Elbow Twisting While Rotating Palm Up
Posted By leecorsack Last Year
leecorsack
leecorsack
Posted Last Year
New Member (67 reputation)New Member (67 reputation)New Member (67 reputation)New Member (67 reputation)New Member (67 reputation)New Member (67 reputation)New Member (67 reputation)New Member (67 reputation)New Member (67 reputation)
Posts: 4, Visits: 38
A bit of an update on this. What I have found is that this is an issue with the IK rig, but if I use FK Mode (not the FK button in IK Mode) to rotate the palm up then I can avoid the elbow twist that is causing the unwanted mesh distortion to the MH. This is a bit of a bummer but a workaround, nonetheless.
Note: I am using Edit Motion Layer
leecorsack
leecorsack
Posted Last Year
Does anyone know why the elbow twists and pinches the mesh when rotating the hand, so the palm is up? I have tried a combination of rotating the hand, the elbow/lower arm the upper arm and I'm at a loss of what the correct procedure is.
I am using iClone 8.42 with live link to UE 5.4. In the attached image I have applied a pose file and used edit motion layer to modify the pose - I have also tried to do this to an animation file as well as the UE MH iAvitar dummy and I am unable to get a favorable result. What am I doing wrong?
