Safe Zone aspect ratio
Posted By JEM618 5 Months Ago
JEM618
JEM618
Posted 5 Months Ago
Veteran Member (891 reputation)Veteran Member (891 reputation)Veteran Member (891 reputation)Veteran Member (891 reputation)Veteran Member (891 reputation)Veteran Member (891 reputation)Veteran Member (891 reputation)Veteran Member (891 reputation)Veteran Member (891 reputation)
Last Active: 4 Months Ago
Posts: 13, Visits: 168
CTA5. From what I can find, there are only two aspect ratios: 4:3 and16:9. I'd like to use 9:16. For now, I've created a white 16:9 PNG to denotethe safe zone, but it seems there must be a better way. Is there a way tochange the aspect ratio? Can the safe area of the stage be adjusted to reflectthis, or could a template be created?
Posted 5 Months Ago
Posts: 23.1K, Visits: 36.6K
Hi...
You are not restricted to just two aspect ratios. You can set the aspect ratio to anything you want.
So in the example below, I changed the resolution in the Render Video panel to 1080 x 1920 (9:16) which is then reflected in the viewport.
https://forum.reallusion.com/uploads/images/b279d0f4-ca8b-4420-ba22-a30b.jpg
JEM618
JEM618
Posted 4 Months Ago
Wow, that’s amazing!! I’d never have found that. Thanks so much.
 Jim
