CC Auto Setup for 3ds Max is Available Now!
Posted By HansRL 2 Years Ago
3
sprattartz
sprattartz
New Member (61 reputation)New Member (61 reputation)New Member (61 reputation)New Member (61 reputation)New Member (61 reputation)New Member (61 reputation)New Member (61 reputation)New Member (61 reputation)New Member (61 reputation)
Posts: 2, Visits: 35
Hi, got a problem where the fbx anim data wont load onto rig, it loads it onto the geo and rips the rig out
iclone 8 /3ds max 2023
help!
amckenzie
amckenzie
Veteran Member (531 reputation)Veteran Member (531 reputation)Veteran Member (531 reputation)Veteran Member (531 reputation)Veteran Member (531 reputation)Veteran Member (531 reputation)Veteran Member (531 reputation)Veteran Member (531 reputation)Veteran Member (531 reputation)
Posts: 38, Visits: 929
Any updates on the Maya beta for this.  Keen to explore further.
Vit3D
Vit3D
Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)Distinguished Member (4.0K reputation)
Last Active: 6 Months Ago
Posts: 917, Visits: 15.1K
Thank You very much for great addon!
I'd like to ask -- Do you plan to add support for converting materials to RedShift format in the future?
RedShift is becoming more and more popular as it is much faster than V-Ray. with almost the same quality.
Vit
davood.kharmanzar
davood.kharmanzar
Posts: 140, Visits: 3.2K
animagic (7/29/2024)
Interested users can gain early access by signing up through an online form."
where is this online form?
luke (RL)
luke (RL)
Group: Power Developer
Posts: 289, Visits: 5.6K
Hi, Schellicon
If possible, could you please send me the FBX file? I’d like to check where the issue might be.
Schellicon (8/2/2024)
in the 2024 version (autosetuo v 1.0.0720.1) it doesn`t import the bones  (skin is empty , no bones in scene , but character is loaded as it should), so biped, cat and face rig cannot work.
import without autosetup has bones imported correctly
same file tested with autosetup in 3dsmax 2025 works perfect!! including biped , cat and face rig! ;D
luke (RL)
luke (RL)
Hi, mbetts_586468
It's a defect. The current workaround is to select the CC_Base_Body mesh and then press the create rig button; that should work.
mbetts_586468 (8/15/2024)
Every time I try to create biped rig it gets stuck at 40% and never finishes the rig setup. Tested in 2023 and 2025, same issue
Can anyone help?
mbetts_586468
mbetts_586468
Posts: 1, Visits: 5
Can anyone help?
Schellicon
Schellicon
New Member (43 reputation)New Member (43 reputation)New Member (43 reputation)New Member (43 reputation)New Member (43 reputation)New Member (43 reputation)New Member (43 reputation)New Member (43 reputation)New Member (43 reputation)
Last Active: 5 Months Ago
Posts: 5, Visits: 94
luke (RL)
luke (RL)
Hi, Schellicon
This error is a bit strange. Did you download and install it from the official website? Could you record your actions when the error occurs?
Schellicon (7/31/2024)
hi,1st thanks for building this thing!!
i have some problems when creating a rig as a biped i got these error  messages:
Traceback (most recent call last):
  File "F:\AutoSetup_Max\AutoSetup-for-3dsMax\build\rig\bodyrig.py", line 92, in create_body_rig
  File "F:\AutoSetup_Max\AutoSetup-for-3dsMax\build\rig\biped.py", line 39, in create_rig
IndexError: list index out of range
....i have no F drive
am i doing something wrong?
also same on cat rig i get same f drive errors
need help here :)
(i used the 2024 version)
thanks
Thorsten
luke (RL)
luke (RL)
Hi, jmi13
There are two ways to solve it.
1. Close 3ds Max and run the install.bat file again.
2. Copy the lib folder and main.py file into C:\Users\jmi3\AppData\Roaming\Reallusion\3dsMax\2025\CC_Auto_Setup\.
jmi3 (7/31/2024)
I don't have a Reallusion folder here.
c:\users\jmi3\appdata\roaming
3
