CC4: How can I export a character in A-Pose instead of the default T-Pose
Posted By kavise100 Last Year
CC4: How can I export a character in A-Pose instead of the default...
kavise100
kavise100
Posted Last Year
Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)
Posts: 44, Visits: 257
Hello,
I saw a post with similar title but it was for CC3, six years old and did not have a clear answer. I want to use Marvelous Designer and it wants my character to be in A pose. Is there any export settings I can use or way that I can export my character in A pose instead of T pose? I did try to save my character in A pose and used Edit Pose to "set current pose as default" but neither worked as my model is still exporting in a T pose.
Thanks much for any help
Posted Last Year
Last Active: 3 hours ago
Posts: 5.3K, Visits: 16.6K
Plenty of export choices for MD.
Let your character assume desired pose.
Export as OBJ > Character With Current Pose
or
Export as FBX > Clothed Character, select Mesh and Motion, choose "Current Pose" and make sure to uncheck "First Frame in Bind-pose"
kavise100
kavise100
Posted Last Year
Thank you for the response - I was able to add clothes to my pipeline by using FBX format for export.
