can't output with alpha channel
Posted By edmllc 15 Years Ago
JPMA
JPMA
Posted 14 Years Ago
Senior Member (268 reputation)Senior Member (268 reputation)Senior Member (268 reputation)Senior Member (268 reputation)Senior Member (268 reputation)Senior Member (268 reputation)Senior Member (268 reputation)Senior Member (268 reputation)Senior Member (268 reputation)
Posts: 14, Visits: 180
I found what is for me the easiest solution to export an animation to Premiere Pro
First, I create a new project in Animator, I click on Settings and i create a colored background (blue or green, depending on the colors already in the picture, with further chroma keying in mind)
Then i work on the project, up to final phase (video export)
Then i import the project into Premiere Pro, I add a chroma keying effect to the clip, and I erase the background color.
It's easy, it works fine
bigdu.br
bigdu.br
Posted 13 Years Ago
Last Active: 13 Years Ago
Posts: 1, Visits: 1
I'm having problems to export with alpha too!
My main problem is how to remove the imported background that i added as a referece just to place my characters ??
I looked the entire workspace and I couln'd find a single button to remove my background !
How can i change the background to trasnparent, this is not visible at my scene manager like the props and the images layers !
Im very frustaded
Posted 13 Years Ago
Posts: 23.1K, Visits: 36.6K
bigdu.br (1/26/2012)
Im very frustaded
Hi..
You can find out how to remove the original background HERE.
And to find out how to add or change the backround image click HERE.
Hope this helps. :)
jmcconchie
jmcconchie
Posted 13 Years Ago
Senior Member (264 reputation)Senior Member (264 reputation)Senior Member (264 reputation)Senior Member (264 reputation)Senior Member (264 reputation)Senior Member (264 reputation)Senior Member (264 reputation)Senior Member (264 reputation)Senior Member (264 reputation)
Last Active: 12 Years Ago
Posts: 9, Visits: 97
Peter, would you mind pointing me to some further instructions as to what to do in the video editor once you have published to the format you have suggested?  I do need to be able to have my cartoons without background, ie. transparent like a PNG file.  Thanks!  :D
John McConchie
Posted 13 Years Ago
jmcconchie (7/4/2012)
John McConchie
Hi John,
Which video editor are you using?
The process will vary between different editors, but basically you would just load your sequence images into the video editor in the same way you would load a standard video. This is normally done using an Open or Import function to add them to the editor timeline.
Then you can export to a video format of your choice.
