can't output with alpha channel
Posted By edmllc 16 Years Ago
edmllc
edmllc
Posted 16 Years Ago
Senior Member (481 reputation)Senior Member (481 reputation)Senior Member (481 reputation)Senior Member (481 reputation)Senior Member (481 reputation)Senior Member (481 reputation)Senior Member (481 reputation)Senior Member (481 reputation)Senior Member (481 reputation)
Last Active: 16 Years Ago
Posts: 1, Visits: 4
I have read through the forum and found a couple solutions for outputting with an alpha channel but it does not seem to work for me.  I am trying to get a video file that I can use in Adobe Premiere with a transparent background.
I have a photoshop file that I have saved as both a png file and a targa file.  I can import just fine into crazy talk 6.  When I output and bring into Premire, I get the file but it has a white background.
Any suggestions?
Thanks
Ted
Threaded View
Threaded View
Forum Post can't output with alpha channel By edmllc ( 16 Years Ago )
Forum Post Hi Ted, Crazytalk can't output video with a transparent background.... By Peter (RL) ( 16 Years Ago )
Forum Post I'm trying tp export a png or targa sequence with transparent (alpha... By ivanthek ( 15 Years Ago )
Forum Post [quote][b]ivanthek (4/7/2011)[/b][hr]I'm trying tp export a png or... By Peter (RL) ( 15 Years Ago )
Forum Post I'm still having issues with this process, using CTA Pro. I open the... By ivanthek ( 15 Years Ago )
Forum Post The first thing to check is that your image has a transaprent... By Peter (RL) ( 15 Years Ago )
Forum Post Well, as I indicated in my prior post I put a green background to see... By ivanthek ( 15 Years Ago )
Forum Post [quote][b]ivanthek (4/8/2011)[/b][hr]Is there a way to know whether... By Peter (RL) ( 15 Years Ago )
Forum Post Peter, would you mind pointing me to some further instructions as to... By jmcconchie ( 14 Years Ago )
Forum Post [quote][b]jmcconchie (7/4/2012)[/b][hr]Peter, would you mind pointing... By Peter (RL) ( 14 Years Ago )
Forum Post Is there a plan to export to FLV with alpha channel at some point?... By chris_20110502173850374 ( 15 Years Ago )
Forum Post [quote][b]chris_20110502173850374 (5/3/2011)[/b][hr]Is there a plan to... By Peter (RL) ( 15 Years Ago )
Forum Post I found what is for me the easiest solution to export an animation to... By JPMA ( 15 Years Ago )
Forum Post I'm having problems to export with alpha too! My main problem is how... By bigdu.br ( 14 Years Ago )
Forum Post [quote][b]bigdu.br (1/26/2012)[/b][hr]I'm having problems to export... By Peter (RL) ( 14 Years Ago )
