K_Digital
K_Digital
Visits: 1.4K
... Does it make sense to buy popcornfx currently ? In another thread i read that only fx editor 1.x will work with the plugin, what will we do with the current 2.x edior ? Is there a workaround to import particles ?
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
For the moment version 2 of the editor is incompatible with Iclone and it is impossible to import particles from version 2.
K_Digital
K_Digital
Visits: 1.4K
Thanks for the answer !
Will 1.12 come with the RL purchase ? Can 1.12 can connect to the particlefx webpage database and use effects like 2.x does ? I am abit concerned about this may not work.
Warped Reality VFX
Warped Reality VFX
Visits: 8.4K
Hello, K_Digital use this version of the editor. This version can connect to the database but you will not be able to use version V2 effects. This is the version I use to create effects I am currently uploading free effects to the marketplace and I will be selling them as well. I am also in the process of creating a new shader system for CC4 Characters and their clothing to be used in Iclone 8, I hope this helps. PopcornFX-Editor_Setup_v1.12.2.40448_x64.exe
Warped Reality VFX.
K_Digital
K_Digital
Visits: 1.4K
Thank you very much !
But let me ask one dumb question. How does someone create free .iparticle effects , does this require the iclone plugin too ?
Warped Reality VFX
Warped Reality VFX
Visits: 8.4K
You create the particles in the editor, they are saved with a file extension (.pkfs). After you import it into Iclone and then save the effect, it will have the file extension(.iparticle). I am not sure if you need the plugin to bring in your own effects that you create or free ones, you can test this out by bringing in one of my free effects from this forum post. https://forum.reallusion.com/355585/Free-Particle-Share
Warped Reality VFX.
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
K_Digital (4/4/2024) Thank you very much !
2 things the plugin allows: - you have access to all the particle settings, change the texture, change the meshes, etc. - you can import particles from the editor.
K_Digital
K_Digital
Visits: 1.4K
hmm, the files from your links could be used under custom particles. Never mind. Can you tell us where to find your stuff on the marktplace ?
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
K_Digital (4/4/2024) hmm, the files from your links could be used under custom particles. Never mind. Can you tell us where to find your stuff on the marktplace ? As I don't know who you are addressing the previous post to.this is the link of my free particles on the marketplace : https://marketplace.reallusion.com/vfx-mt-pack-free
And this is the link of the others : https://marketplace.reallusion.com/iclone/author/Takerk'ART
K_Digital
K_Digital
Visits: 1.4K
Thank you, your content was easy to find becasue of your name, i mainly meant Kevin L. Its not easy to guess who he is on the market place.
