Does it make sense to buy popcornfx currently ?
https://forum.reallusion.com/Topic550380.aspx
Print Topic | Close Window
By K_Digital - 2 Years Ago
... Does it make sense to buy popcornfx currently ?
In another thread i read that only fx editor 1.x will work with the plugin, what will we do with the current 2.x edior ?
Is there a workaround to import particles ?
By mtakerkart - 2 Years Ago
For the moment version 2 of the editor is incompatible with Iclone and it is impossible to import particles from version 2.
Is it impossible to create your requirement with version 1.12?
Marc
https://marketplace.reallusion.com/iclone/author/Takerk'ART
Thanks for the answer !
Will 1.12 come with the RL purchase ?
Can 1.12 can connect to the particlefx webpage database  and use effects like 2.x does ?
I am abit concerned about this may not work.
By Warped Reality VFX - 2 Years Ago
Hello, K_Digital use this version of the editor.
This version can connect to the database but you will not be able to use version V2 effects.
This is the version I use to create effects I am currently uploading free effects to the marketplace and I will be selling them as well. I am also in the process of creating a new shader system for CC4 Characters and their clothing to be used in Iclone 8, I hope this helps.
PopcornFX-Editor_Setup_v1.12.2.40448_x64.exe
Thank you very much !
But let me ask one dumb question.
How does someone create free .iparticle effects , does this require the iclone plugin too ?
You create the particles in the editor, they are saved with a file extension (.pkfs).
After you import it into Iclone and then save the effect, it will have the file extension(.iparticle).
I am not sure if you need the plugin to bring in your own effects that you create or free ones, you can test this out by bringing in one of my free effects from this forum post.
https://forum.reallusion.com/355585/Free-Particle-Share
K_Digital (4/4/2024)
2 things the plugin allows:
- you have access to all the particle settings, change the texture, change the meshes, etc.
- you can import particles from the editor.
hmm, the files from your links could be used under custom particles.
Never mind.
Can you tell us where to find your stuff on the marktplace ?
Never mind.
As I don't know who you are addressing the previous post to.this is the link of my free particles on the marketplace :
https://marketplace.reallusion.com/vfx-mt-pack-free
And this is the link of the others :
Thank you, your content was easy to find becasue of your name, i mainly meant Kevin L. Its not easy to guess who he is on the market place.
By animagic - 2 Years Ago
K_Digital (4/5/2024)
You have to check his Youtube videosas provided in this thread https://forum.reallusion.com/355585/Free-Particle-Share.
The links to his particles are in the video descriptions.
Hello, K_Digital I have not published them yet they are on the marketplace backend I will publish some later tonight or tomorrow, I am in the process of making videos to demonstrate the effects and I don't know how long, Reallusion will take to show the effects, on the marketplace.
Thank you for your interest.
Ah i see, thanks to everyone again !
Purchased the plugin last night,
Does anyone know if i could use the newer editor for creating effects, then load them into the older one in order to store pkfx for Iclone ?
.. and can i installd both editors at the same time ?
K_Digital (4/12/2024)
The particles created in the V2 can't be imported in the V1.
Yes you can install the V1 and V2 Popcornfx editor on your PC.
mtakerkart, beat me to it, also just an update the Warped Reality VFX store is open I have a few effects up there and will be adding more almost every other day I have a few more going up today.
Warped Reality VFX
