FBX Re-import issues
Posted By Parallel World Labs 2 Years Ago
Parallel World Labs
Parallel World Labs
Junior Member (210 reputation)Junior Member (210 reputation)Junior Member (210 reputation)Junior Member (210 reputation)Junior Member (210 reputation)Junior Member (210 reputation)Junior Member (210 reputation)Junior Member (210 reputation)Junior Member (210 reputation)
Posts: 15, Visits: 130
Hello, I'm importing iClone 8 metahuman animations into Unreal as FBX. The pipeline works.
What's weird though is that I'm having problems re-importing the FBX sometimes, if I make a change in iClone and re-export the same motion with the same file name, same character mesh, skeleton, duration etc. Literally just tweaking some curves etc.
It works WHEN: I don't close the iClone file. If I make a change and re-export, then I can use the re-import feature in Unreal and it just re-imports using all the same settings and updates the asset.
It doesn't work WHEN: I close the iClone file and re-open it and then re-export. Unreal says the following: "could not find needed track".
I suspect this has something to do with the "tempmotion" meta-data embedded in the FBX file, with some unique GUID or something. I have heard there is a workaround by manually text editing the FBX file??!
Surely there's some way around this?
fbx
Threaded View
Threaded View
Forum Post FBX Re-import issues By Parallel World Labs ( 2 Years Ago )
