mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
Hi , could someone try if the particles Glow setting is effective ? Mine not... Just to be certain . Thank you
jlittle
jlittle
Posts: 1.9K,
Visits: 17.3K
Hey mtakerkart, Works fine for me in iC8. Jeff
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
Thank you Jeff ,
Stange , I reinstalled Iclone and the PopcornFX plugin but the issue persists.... It's only with the glow particles , the glow textures for props , character works fine.
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
Sorry to resurrect this thread but technical support is slow to respond to me. Could someone do a test with windows 11 and an nvidia rtx graphics card in the 30 series? Mine is 3060 rtx. This video shows my problem. On my other PC in Windows 10 I have no problem.
Thank you very much for your helps
Last Active: Today @ 12:03 AM
Posts: 5.3K,
Visits: 16.8K
It does not work right in IC8 (Explosive Bloom strength is always at max regardless of dial). Works fine in IC7 on the same computer. And it is not an issue with .ipkfx file itself. I can load it from IC8 Content into IC7 and it still works. So it's an issue of IC8 for sure...
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
4u2ges (3/30/2024) It does not work right in IC8 (Explosive Bloom strength is always at max regardless of dial). Works fine in IC7 on the same computer.
Thnak very much 4u2ges. Does it works on your IC7 with windows 11 ?
Posts: 5.3K,
Visits: 16.8K
Thank very much 4u2ges. Does it works on your IC7 with windows 11 ? No problem, but I am still with Windows 10. I do not think the OS is an issue though...
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
4u2ges (3/30/2024)
Thank very much 4u2ges. Does it works on your IC7 with windows 11 ? No problem, but I am still with Windows 10. I do not think the OS is an issue though... I think yes ;) because on my PC with windows 10 and Iclone 8 it works. So I think that Iclone 8 on windows 11 is broken with the particle.
It's not only with the glow setting , it's also with Distorsion strength.
Posts: 5.3K,
Visits: 16.8K
Damn! But then why it does not work on my Windows 10 PC in iClone8 and it does in iClone7? There must be something else... Are you running the same IC8 version on Windows 10 and Windows 11? There was an issue with Glow control values last year, which they seems to fix in the latest update. Wonder if that broke popcornFX bloom...
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
4u2ges (3/30/2024) Damn! But then why it does not work on my Windows 10 PC in iClone8 and it does in iClone7? There must be something else...
OH!! You're right . On my windows 10 PC it's the IC8 V 8.31. The latest version , 8.4 is broken with glow particles.
