Particles Glow issue ?
https://forum.reallusion.com/Topic548379.aspx
Print Topic | Close Window
By mtakerkart - 2 Years Ago
Hi , could someone try if the particles Glow setting is effective ?  Mine not...
Just to be certain .
Thank you
By jlittle - 2 Years Ago
Hey mtakerkart,
Works fine for me in iC8.
Jeff
Thank you Jeff ,
Stange , I reinstalled Iclone and the PopcornFX plugin but the issue persists....
It's only with the glow particles  , the glow textures for props , character works fine.
Sorry to resurrect this thread but technical support is slow to respond to me.
Could someone do a test with windows 11 and an nvidia rtx graphics card in the 30 series? Mine is 3060 rtx.
This video shows my problem. On my other PC in Windows 10 I have no problem.
Thank you very much for your helps
By 4u2ges - 2 Years Ago
It does not work right in IC8 (Explosive Bloom strength is always at max regardless of dial).
Works fine in IC7 on the same computer.
And it is not an issue with .ipkfx file itself. I can load it from IC8 Content into IC7 and it still works.
So it's an issue of IC8 for sure...
4u2ges (3/30/2024)
Thnak very much 4u2ges. Does it works on your IC7 with windows 11 ?
Thank very much 4u2ges. Does it works on your IC7 with windows 11 ?
No problem, but I am still with Windows 10.
I do not think the OS is an issue though...
4u2ges (3/30/2024)
I think yes ;) because on my PC with windows 10 and Iclone 8 it works. So I think that Iclone 8 on windows 11 is broken with the particle.
It's not only with the glow setting , it's also with Distorsion strength.
Damn!
But then why it does not work on my Windows 10 PC in iClone8 and it does in iClone7?
There must be something else...
Are you running the same IC8 version on Windows 10 and Windows 11?
There was an issue with Glow control values last year, which they seems to fix in the latest update.
Wonder if that broke popcornFX bloom...
4u2ges (3/30/2024)
Damn!
OH!! You're right . On my windows 10 PC it's the IC8 V 8.31.
The latest version , 8.4 is broken with glow particles.
By rosuckmedia - 2 Years Ago
Hi Mark
I tried it
I use Windows 11
It doesn't work in iClone 8
In iClone 7 it works fine.
Greetings Robert
Thank you rosuckmedia !
I sent this thread to technical support
Marc,
I tested and the bloom works fine in iC8.31 (RTX2080) on Win10 but not in iC8.4 on Win11 (RTX4090).
Jeff
So the 8.41 update of Iclone didn't fixe the problem...
It seems that the feedback tracker is taken more seriously than a support ticket.
so I created a feedback tracker :
https://www.reallusion.com/FeedBackTracker/Issue/Particles-Glow-settings-broken
Issue 11263
By BiggsTrek - 2 Years Ago
mtakerkart (4/18/2024)
Sadly, I found the same thing.  I reported a problem last year, and later was told it must have "fallen through the cracks" (direct quote from Rampa of support.)  I was advised to add the issue to the feedback tracker.  Pretty lousy solution if you ask me.  What's the point of raising a support ticket?!?  Not happy with their support team AT ALL.
[/rant over]
BiggsTrek (4/18/2024)
[/rant over]
I would moderate your words a little.:-)
I created a support ticket, which was suggested to me by Peter, to be able to return to version 8.3
and it was resolved in 2 days.
I think that when the problem requires intervention from the Taiwan office which seems to be the developers of Iclone, it is the feedback tracker which is preferred.
By K_Digital - 2 Years Ago
Taiwan ? :ermm: thought i am buying american quality :crying:
Has aonyone tested the all the paticles  on IC8,5x yet ?
mtakerkart , have you moved on to IC84 / 8.5 in the meantime ?
K_Digital (11/14/2024)
Yes. I use 5.1 and the glow particles works.
https://forum.reallusion.com/uploads/images/1a1e2f49-66f2-424b-893a-ea12.gif
Thank you, cant still decide to update to 8.51 when i look at that feedbacktracker buglist :-(
