Animate terrain
Posted By bpinonto Last Year
Animate terrain
bpinonto
bpinonto
Posted Last Year
Veteran Member (952 reputation)Veteran Member (952 reputation)Veteran Member (952 reputation)Veteran Member (952 reputation)Veteran Member (952 reputation)Veteran Member (952 reputation)Veteran Member (952 reputation)Veteran Member (952 reputation)Veteran Member (952 reputation)
Posts: 77, Visits: 154
Hi,
How to animate terrain?
For example, in frame 1, I set some height offset and then in frame 100 I increase the height offset.
So that the terrain moves higher.
How to make this?
Benny
Posted Last Year
Posts: 15.8K, Visits: 31.3K
You cannot animate a terrain. You would need a prop in the shape of a terrain.
bpinonto
bpinonto
Posted Last Year
Ok.
How about water? Can you animate the level of water?
Posted Last Year
bpinonto (1/5/2024)
Ok.
Unfortunately not with the built-in water.
Posted Last Year
Posts: 5.3K, Visits: 16.6K
You can level the water with some limitation.
Water prop does not have timeline transform track so the key would be hidden and you have to add the flag in project track to note where the level key is.
So if you uncheck Transform Gizmo (and Snap to Grid if checked) in Preferences you may rise/lower water prop level by hitting W and use mouse scroll wheel.
76% of original size (was 661x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/e240a4ae-20db-4108-99ea-61d3.gif
Posted Last Year
Thanks, 4u2ges. Learning something every day..:unsure:
Posted Last Year
Posts: 8.2K, Visits: 62.5K
For animated terrain beyond XYZ scaling of a prop, you can import an Alembic file. If you use Motion Director to animate your characters, they will follow the animated terrain surface as it moves.
thebiz.movies
thebiz.movies
Posted Last Year
Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)
Posts: 2.1K, Visits: 42.3K
4u2ges (1/5/2024)
Wow!  Very cool.
