UV mapping for multi materials possible in Character Creator?
Posted By kavise100 3 Years Ago
kavise100
kavise100
Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)
Posts: 44, Visits: 257
Hello,
I just got CC4 and I'm wanting to import an FBX accessory with multiple textures, but when it comes into CC4 it's uv's get tweeked/combined/erased, so the embedded textures can no longer be applied to the object. The object has multiple material ID's, each with it's own set of UV's and a separate material applied: Picture a T-shirt split down the middle with all the polygons on the right assigned to material A and all the polygons on the left assigned to material B (my screen shot shows a ball, but it's the same idea)
If I import this to Blender or Max, the UV data is intact, but
When it's imported to CC4 it shows up white, and with only a single material applied, and a single set of uv's (as far as I can tell, but I have not figured out how to unwrap in CC4)
Since the UV mapping gets wiped out on import, I'm wondering if I can just completely re-map and re-texture it in CC4? Is it possible to uv map an accessory in CC4 with two materials, each with it's own set of uvs?
Thanks much for any info
