Sorry to hear you are having these problems exporting.
It is obviously not a general bug with the software as the vast majority of users have no trouble exporting so something else is causing the problem.
One thing that can cause these type of problems is if you have a shortage of drive space for the temporary files generated during export. By default temporary files are saved to the C: drive so do make sure you have plenty of free space (more than 20GB recommended). Sadly with small SSD drives fitted as the C: drive, limited space can be a common problem.
I would also recommend trying the export process with just the default figure (no hair, clothes, motions etc.). Does this export or does it still crash?
Finally, if you can post your full system specs, including graphic card, this can also help identify any problems. Thanks.
