Use your own body?
Posted By Smit_R 3 Years Ago
Smit_R
Smit_R
Veteran Member (731 reputation)Veteran Member (731 reputation)Veteran Member (731 reputation)Veteran Member (731 reputation)Veteran Member (731 reputation)Veteran Member (731 reputation)Veteran Member (731 reputation)Veteran Member (731 reputation)Veteran Member (731 reputation)
Posts: 83, Visits: 5.5K
Hi there,
I've got a fullbody character in .obj format and I want to use Accurig and Headshot 2.0 to make a full controllable character out of it.
Can someone point me in the right direction to achieve this?
Because I can rig the character with Accurig and I can create a perfect match of the head with Headshot 2.0, but not combined?
I can't find the option to use my own body in 'Attach to body' besides the default ones.
Hope someone can enlighten me, allthough I'm afraid It's not possible.
Sophus
Sophus
Veteran Member (820 reputation)Veteran Member (820 reputation)Veteran Member (820 reputation)Veteran Member (820 reputation)Veteran Member (820 reputation)Veteran Member (820 reputation)Veteran Member (820 reputation)Veteran Member (820 reputation)Veteran Member (820 reputation)
Posts: 230, Visits: 2.6K
This can be done with the tool R3DS Wrap. It works the same way as Headshot 2 but can convert the whole 3d model and not only the head.
Otherwise you have to do it manually, for example by importing the head via Headshot 2 and then using CC to modify body so that it looks like your original 3d model.
Or you export the CC base mesh to blender and deform it until it looks like your 3d model.
But I wouldn't be surprised if Reallusion will add the option in the future to import and convert complete base meshes. They already have the technology to rig non-CC meshes and they already can import non-CC heads. The only thing missing is the conversion of the body part.
Smit_R
Smit_R
Thank you for your answer, Sophus.
My point exactly. Because I already can rig a non-CC mesh at this moment I presumed this combination would already be possible.
I'll have to take another route in this case. Problaby using a body from the Cartoon Character Designer pack and go from there.
Thanks again.
Posts: 9.2K, Visits: 22.1K
Sophus (6/23/2023)
Yeah, don't hold your breath.  If this was possible they would have done it already.
Headshow 2 really only leverages the tech they use in Transformer, which is to remap a mesh head to fit the CC3+ one.  THAT tech already existed, they only had to adapt it.  But mapping the entire body to the CC3+ one?  Ain't gonna happen.
I think your best bet for now is to create two different avatars and line them up (you can do this with the tools in Headshot) and then delete the mesh on the CC3+ one's body, and the head on the Accurig one.
Posts: 5.3K, Visits: 16.8K
I have done it a few times and have a stable routine: https://forum.reallusion.com/FindPost525237.aspx
Introduction of Headshot 2 opens up a lot more possibilities here.
In your case it's a little more work attaching head to the body in Blender, but also quite doable with enough skills.
Also routine may vary and be simplified if you have an OBJ for the body.
Here is Mixamo Medea with CC3+ head combo made with this method.
https://forum.reallusion.com/uploads/images/f01a117a-4eee-4f92-9da6-3cd0.jpg
eljofa
eljofa
Veteran Member (682 reputation)Veteran Member (682 reputation)Veteran Member (682 reputation)Veteran Member (682 reputation)Veteran Member (682 reputation)Veteran Member (682 reputation)Veteran Member (682 reputation)Veteran Member (682 reputation)Veteran Member (682 reputation)
Posts: 76, Visits: 507
And, can You import the model to cc4 and iclone for Animation??
Thank you ❤️
Cheers
Smit_R
Smit_R
Thanks for replying @all.
For me this upgrade of Headshot doesn't came at a better time as of now.
Since just recently I'm working on a project where I need a 1-1 conversion of a toon model which is just an obj-file. She must be able to act, talk etc.
Without reading the manual (off course) and after watching the only 2 video's of Reallusion I just started and stumbled on this only issue. Getting the body and facial rig to work at the same time.
From a previous post of Eljofa, Peter(RL) replied only CC3+ are compatible for a body. (Still without reading the manual) And because I already own the Cartoon Character Designer Pack I chose that route. I converted the CC3 body mesh to CC3+.
My Blender knowledge is not that shabby, but I want to do this primarely in CC4.
So far I'm quite happy with the results.With the body morph sliders I'm able to match the body to the original imported body mesh. Matching textures and of course some minor tweaking/sculpting will be done in Blender.
The results of just pointing out 35 points on a static head is quite extraordinary in my book. This is only with some moving and smoothing in HS2,
@Kelleytoons Well, tech for creating an CC armature on a non CC-mesh is there, so I kinda hoped it would be possible with the new Headshot version to combine these two. I guessed wrong apparently. *Fingers crossed for the next update?* Or a Bodyshot plugin? :rolleyes:
@4u2ges Many thanks for showing this (very clever) method, but the problem still remains. After you do your conversion to CC4, you can't use HS2 with that body in CC4.
PS, This is still a WIP. ;)
mrtobycook
mrtobycook
Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)
Posts: 425, Visits: 2.7K
Bumping this.
It’s very frustrating that we can’t use custom bodies with Headshot 2 - we can’t even use MetaHuman Dummy bodies in it.
So is there a way to convert custom bodies to cc3+ format? No, right?
https://forum.reallusion.com/uploads/images/d11fc97b-7387-4f19-bb1e-0785.png
virtualfilmer.com | youtube
Garry_Seven_of_one
Garry_Seven_of_one
Posts: 457, Visits: 1.9K
mrtobycook (9/2/2023)
Bumping this.
I’m just using Zwrap plug-in in Zbrush to wrap custom body to CC3+ neutral body then create body morph in CC4
Garry, Clearstream, Seven_of_one
https://forum.reallusion.com/uploads/images/f8c0246a-f887-417d-9f3c-b22c.png
My Pinterests
mrtobycook
mrtobycook
Zbrush is one of my big blind spots. But ok I’ll have a think and maybe have to learn it haha
