Depthmap render
Posted By dassoubarna 3 Years Ago
dassoubarna
dassoubarna
Last Active: 4 days ago
Posts: 49, Visits: 685
I want to create 3D image for Facebook. Is there any way to render a depthmap in iClone ?
Please suggest a way to do it. Thanks in advance.
Terry Miller
Terry Miller
Posts: 96, Visits: 2.2K
If I am correctly understanding what you are asking, I would try this:
Remove or turn off all lights in a scene, and uncheck Activate IBL under the Visual tab. In short, remove or turn off anything that will emit any light; your scene should be pitch black (as far as models are concerned; if you don't have a sky, that part will still be the default color [usually gray]).
Under the Visual tab again, check Fog On. The distance is set by default at Start: 10,000, and End: 20,000. I would change this; you will have to play with it to get the effect you want, but I would begin with Start: 1 and End: 100,000, and tweak from there. You should begin to see the effect that you are looking for.
I hope this helps.
Best,
Terry
dassoubarna
dassoubarna
Thanks!
3dtester
3dtester
Posts: 999, Visits: 2.2K
Hi, i had the same question and found a really easy way to create depth maps with iClone, using the Iray preview renderer.
Here is a scene that i loaded in iClone.
In the Iray render options only Depth is selected
It quickly renders a nice depth map.
Hope that anyone finds this useful, too :)
