Noitom Mocap / PN3 Best Practices for 24fps
Posted By lightbearer 3 Years Ago
lightbearer
lightbearer
Veteran Member (859 reputation)Veteran Member (859 reputation)Veteran Member (859 reputation)Veteran Member (859 reputation)Veteran Member (859 reputation)Veteran Member (859 reputation)Veteran Member (859 reputation)Veteran Member (859 reputation)Veteran Member (859 reputation)
Last Active: 4 days ago
Posts: 88, Visits: 530
I am attempting to ascertain best practices when using Axis Studio and PN3 in relation to frame rate for iClone 8. Currently, I will either stream or capture the mocap in a 24p project in iClone vs. setting iClone 8 to 60p. Does anyone know if this poses a problem? Should I set iClone 8 to 60p and then later change the project settings to 24p? Would this affect audio?
Posts: 9.2K, Visits: 22.1K
It doesn't matter the frame rate when you talk about audio - audio is a whole different ballgame and is the same "rate" regardless of the frame rate.
My workflow is to capture in iClone 7 (only because it's less resource hungry) at the "normal" default 60fps and transfer over to 8 where I DO output at 24 fps (single frames for animation, of course). It works fine that way, even with two PN3 suits at the same time (however, I use the "dummy" avatar in 7 as a position holder, even when I'm also capturing facial animation at the same time, because it's less resources.  This CAN be an issue depending on the sets you are using).
